Centred LC/LJ drop tanks
#1 _Machine_
Posted 06 July 2009 - 09:23 PM
(according to tank builder) If it was centred hanging below the boot but flat not extending up into the boot like the XU-1 tanks. Due to exhaust hangers and limitation of space it would only be about 45 litres.
But if it was to extend up into the boot a la XU-1 would be 65-70 Litres.
What would you guys reckon would be best and what would you want?
Does anyone have plans for a centred LJ drop tank i could look at?
What do you think would be an attractive price?
And other features like baffles (obviously), rear pickup for drag/occasional drag racing etc.
Any other ideas??
Put em forward and I`ll see if we can organise a group buy if interested.
M.
Posted 07 July 2009 - 09:38 AM
I dropped mine an extra inch or two unsure on volume! Mate built mine.
No idea on centre tank! Will u have room for exhuast?
Posted 07 July 2009 - 10:02 AM
Posted 07 July 2009 - 11:30 AM
I had thought of getting one of the streatneat tanks without top of the fuel tank welded on so it could be modified to suit an efi car & an internal fuel pump then thought would be better to just get a custom tank made so it's centred more to suit twin exhausts.
Features planned so far:
centred fuel tank
vdo fuel sender
drain bolt at bottom
some baffling/swirl pot
internal pump if possible (like an 044)
removable inspection cover on top(so tank can be cleaned
filler pipe similar to xu1 so tank is legal
3 weld on fittings for
1:return line,
2:feed line for external pump(suit nitrous or just a carby set up)
3:tank ventilation line or line from charcoal canister(if efi)
Tank would be atleast 50-60 litres in capacity,centred & have the tank sit higher as in more of it in the boot so it barely noticeable when you look from the back of the car.Look nicer in my opinion.
Not real keen on how I had the car before with lift pump,surge tank,efi pump & fuel hoses in the boot.It will probably have twin remote boosters in there also.I'd also like the keep the option open to running nitrous.
So yeah,I've thought about it lol.
I'll probably go have a chat to MrEnforcer about it if I ever get the chance or a new guy that worked at Mick's Metalcraft before they re-located.No idea on the quote yet.
Let us know what you can come up with or any other ideas.
#5 _Torana308_
Posted 07 July 2009 - 11:29 PM
Edited by Torana308, 07 July 2009 - 11:34 PM.
#6 _Machine_
Posted 07 July 2009 - 11:55 PM
Capacity?
Cost?
Ta, M.
Posted 08 July 2009 - 12:12 PM
Thnks mateThats nice bart; real nice - where did u get it done?
Capacity?
Cost?
Ta, M.
I will make up a boot floor mat to cover up the mouting around the edges of the top of the tank. The tank it self will still be seen on the top.
Capacity is about 90 liters? Not sure as i have changed the size from template so its a little smaller from originally designed
I actually made up the tank, floded, bent and cut the peices out, the welding was done by Leigh at extreme turbo manifolds.
It has baffles welded in also, and the two lids on top allow access for foam.
Posted 08 July 2009 - 12:43 PM
Thnks mate
The last pic was from the first tank i made but scrapped
#9 _LHoon_
Posted 08 July 2009 - 01:20 PM
M.
What kind of price are you thinking?
#10 _Machine_
Posted 08 July 2009 - 04:38 PM
Posted 08 July 2009 - 04:59 PM
You may have to add $300 on top of that unfortunately. Never know someone may be able to do it. The materials cost about $300-$400, including the bungs/weld on fittings etc, im sure im forgetting other bits but thats roughly what your looking at i think as i havnt costed it properly.$600 ish
May be able to do mild steel cheaper?
Edited by Bart, 08 July 2009 - 05:01 PM.
#12 _Machine_
Posted 08 July 2009 - 07:37 PM
One as flash as yours I`m sure would be a little extra (hopefully not =)
well see i`ll keep yas posted.
M.
Posted 09 July 2009 - 02:41 AM
Posted 09 July 2009 - 03:11 PM
Mild steel is less prone to cracking and leaking along the welds compared to alu etc
Then finished with aluminium coating.
Posted 09 July 2009 - 05:09 PM
Just to answer your question directlyhey guys after some feedback. (looking at getting a tank built)
Any other ideas??
M.
I think an Xu1 style or similar would be good as the extra capacity is needed if you dont want to fill twice a week, but it would need baffles and or foam for fuel sloshing around
Price wise $800+ unless made in China. But then quality would be an issue and would be an issue for others to have a Chinese product in an Australian car. (Ishouldnt critisize since i have Jap parts in mine)
#16 _Machine_
Posted 10 July 2009 - 12:29 AM
Just think the drop tank looks tougher and suits the style of the car i want to build.
M.
Posted 10 July 2009 - 09:41 AM
#18 _Machine_
Posted 10 July 2009 - 11:24 AM
I`d swap the xu-1 tank for a drop tank (+ cash depending on the tank) if i found one.
Although if this guy comes thru then its all good.
M.
Edited by Machine, 10 July 2009 - 11:27 AM.
Posted 10 July 2009 - 12:06 PM
You may need to cut the hole in the boot to get the tank centre??yeah mate but to also sit centred not off to the side.
M.
Or off set the bottom of the tank so its in the middle.
#20 _Machine_
Posted 10 July 2009 - 08:01 PM
Cheers, M.
#21 _beergut_
Posted 10 July 2009 - 09:33 PM
want a drop tank for my lh and wouldnt mind getting a quote
every where else is 1000 and up plus frieght!!!!!!
#22 _Machine_
Posted 12 July 2009 - 12:36 AM
#23
Posted 12 July 2009 - 07:21 PM
Are you doing aluminium or mild steel?yeah mate, once i see the tank and the finished product and can verify the quality i`ll let u guys know straight away.
#24 _Machine_
Posted 12 July 2009 - 10:33 PM
#25 _LHoon_
Posted 20 July 2009 - 12:16 PM
