Installing front speakers
#1 _LC2250_
Posted 24 March 2006 - 05:49 PM
I'm just curious how other people with LC or LJ's have gone about installing speakers in the front. I'm hoping to be able to put in 5" or 6" speakers.
People that have done this? did you make something up or cut something apart ...
Any pointers would be greatly appreciated
-Al
#2 _73LJWhiteSL_
Posted 24 March 2006 - 06:06 PM
Steve
#3 _LC2250_
Posted 25 March 2006 - 02:35 AM
Steve, you wouldn't happen to have a picture of this setup you have? I'm quite curious and very grateful if at all possible.
#4 _high_rpm_
Posted 25 March 2006 - 11:06 AM
#5 _73LJWhiteSL_
Posted 25 March 2006 - 11:44 AM
I didn't want to cut the metal, so I did build up a 'POD' like thing if you like. A layer of 3mm MDF the same size as the kickpannels, and then a smaller layer of 12mm MDF and then another smaller layer of 12 and then 3 'doughnuts' of 12mm MDF. The only thing I found was the 3mm MDF was too big to fit into the pinchweld of the door like the orginal kickpannels, so maybe a thinner piece of wood, or a piece of Macenite would work better. They are secured by 'nutsets' (think of popriverts with a thread in them) located in the webs accross the channel just before the door.
Also the speakers are in a sealed mount, with a small port (what the wire was comming out in these pictures ). Since those pictures have been taken I have mounted the crossovers and the tweeters on the kick pannels, mounting the tweeters just above the bottom mounting bolt and faced them accross the car and I reckon it sounds really good. That was the best place I found to mount them. The only problem I had with mounting the crossovers on the kick pannels was I had to relocate the fuse box about 2" to the left, but that was fairly easy.
I am planning to carpet the top half, and paint the bottom half the same colour as the kickpannels were. I don't have any problems with this setup despite how close it is to the accelorator pedal, but then I don't have big feet. If you have big feet this may not be the setup for you.
Hope this has given you some ideas.
Steve
Edited by 73LJWhiteSL, 25 March 2006 - 11:48 AM.
#6 _LC2250_
Posted 02 April 2006 - 10:07 PM
Sorry I didn't reply ... been kinda busy and hadn't even thought about the idea again until now. Those pictures give me a much better idea as to what you mean ... I had some really stupid interpretations in my mind as to what you initially meant but it's clearer now and I also think thats the most ideal place for the speakers to be (practicality/functionality/aesthetics).
The wiring in that car reminds me of my car ... all these teeny tiny little unfinished projects rearing there ugly heads about the place
Is that your headunit mounted in the glovebox? I may be confusing it with something ... I tried doing that but got pissed off about placement and stuff. Your obviously very conscious of security if it is ...
Thanks a heap for your help so far ... if I have any more questions and you can still be bothered I'll send you a line.
-Al
#7 _devilsadvocate_
Posted 03 April 2006 - 06:20 AM
#8 _73LJWhiteSL_
Posted 03 April 2006 - 01:27 PM
After much thinking measuring and contemplation, defiantely this is the best place i believe.
My headunit is not mounted in the glovebox, but in a modifed under dash unit from another LJ. This pic may help you to see that
Realise its not a simple choice as there are compromises elsewhere......
Definately agree with you on this one.
However this solutions was the best for me.
My critereia was
1. No cutting of metal anywhere.
2. No cutting of door trim.
Now that you have seen my criteria you will probably understand why I mounted them where i did. The sound isn't perfect, but if i want perfect i will build a house and install a home cinema... you won't get perfect sound in a car, and especaily not a car that is nearly 33 years old.
Steve
#9 _LC2250_
Posted 03 April 2006 - 03:10 PM
The main reason I'm putting these front speakers in is because when you drive with passengers in the back on a highway to have the sound at a bearable volume for the back passengers the front people cannot hear the music at all. I guess I could also fix up the seals on the doors but I doubt I'll be able to greatly reduce it sounding like the occupants are in a wind tunnel. Anyone have an opinion as to whether it's more the door seals or is it more requiring sound deadening for the body?
hmm
-Al
#10 _73LJWhiteSL_
Posted 03 April 2006 - 09:00 PM
I agree with you about the back speakers, no front speakers and passengers in front and back. Did that in both the Mazda and Torana at the start. You just gotta have front speakers.
Steve
Posted 04 April 2006 - 06:27 PM
I did this on my LX, and it worked well.
#12 _73LJWhiteSL_
Posted 04 April 2006 - 07:24 PM
The LJ had screw in holes in the bottom front of each of the kick pannels. I sealed the holes up with sealer (without screws you get water in the car from there ) Other than that LJs have no clips that i could see.
Thanks for the vynal tip. Didn't even think of that one. Might have to have a go and see if i can do that
Steve
Posted 05 April 2006 - 12:25 PM
Yeah, sorry, brain was in LH/LX section, not LC/LJ section . The LC/LJs only had screws holding the panels in. The LH/LXs had the plastic push in clips.gday Dangerous,
Steve
#14 _gtr-xu1_
Posted 05 April 2006 - 01:10 PM
man those are the days AM radio in mono sound
#15 _high_rpm_
Posted 05 April 2006 - 02:46 PM
put a sub in there OMG ULEH!whats wrong with the single speeker factory location under the dash?
#16 _73LJWhiteSL_
Posted 05 April 2006 - 08:48 PM
Mine wasn't optioned with the AM Radiowhats wrong with the single speeker factory location under the dash?
Steve
Posted 05 April 2006 - 10:08 PM
#18 _LC2250_
Posted 10 April 2006 - 02:29 AM
So many fun ways I can do this ... but meh to that ... I think I want it to be easiest now.
Mine also had no AM radio ... don't know how the old lady that owned the rana before me managed with no music ... or at least sound/noise in the car (noise aside from wind RUSHING through every orrifice of the car).
-Al
#19 _devilsadvocate_
Posted 10 April 2006 - 10:56 AM
Even a simple am radio back in the mid 70's would have added at least $100 to the price of a car( in todays money quadruple that),more cars were being fitted with them as standard, but during 60's only top of the line models got them.Mine also had no AM radio ... don't know how the old lady that owned the rana before me managed with no music
Most people drove around without them, they were expensive aftermarket too.
Edited by devilsadvocate, 10 April 2006 - 10:59 AM.
Posted 15 April 2006 - 09:00 PM
i come up with an easy (albeit probably not legal) setup.
Take 1 (one) 2 Way speaker from home entertainment system.
Unplug factory speaker.
plug aforementioned 2 way speaker into wires left over from factory setup.
place 2 way speaker between front seats, and BOP!
RIM
#21
Posted 15 April 2006 - 11:44 PM
#22
Posted 16 April 2006 - 08:54 PM
Check out my CarDomain page, the bottom pics are of my current setup.
http://www.cardomain.com/ride/2288805
It was just a quick job, but it works fairly well.
The speakers are $20 worth, and come with brackets and screws etc. They are outdoor speakers, but work alright for me.
I havent put any under the driver side dash, but you can get smaller speakers (about 150x150mm) that i will fit when i get around to it.
Cheers, RIM
#23 _LC2250_
Posted 17 April 2006 - 02:50 AM
Hey guys. i found a solution to all our problems (except that we cant legally put a 454 in an LJ).
haven't solved all problems then have you!
hmm, thats quite interesting what you've done with the outdoor speaker there ... think it could fit anywhere on the drivers side in a 'balanced' way?
-Al
#24
Posted 17 April 2006 - 12:39 PM
Cheers, RIM
#25 _Bomber Watson_
Posted 17 April 2006 - 07:36 PM
my hot setup.
