Installing front speakers
#26
Posted 17 April 2006 - 08:21 PM
Not all of us, however, have funds available to do a full retrim. I think my idea (outdoor speakers) works pretty well for those on a pretty tight budget, and they can be hidden pretty well.
RIM
#27 _devilsadvocate_
Posted 17 April 2006 - 09:00 PM
Why would you need to retrim the car to put speakers in the doors?Not all of us, however, have funds available to do a full retrim. I think my idea (outdoor speakers) works pretty well for those on a pretty tight budget, and they can be hidden pretty well.
I can understand not wanting to cut into the original trims if the car was being entered in shows as completely original etc, but otherwise think people are being a unnecessarily precious about their original vinyl trims and door inners.
Im sure Bomber's setup sounds heaps better than any speaker setup thats been mooted so far.
#28
Posted 17 April 2006 - 09:19 PM
RIM
can we please not let his get into an argument, the forum is here to give people ideas on installing front sspeakers
#29 _devilsadvocate_
Posted 18 April 2006 - 12:08 AM
Rim101:Fair enough, but your implication was that your speakers couldnt go in the doors because the cost of retrimming a car was too expensive, why mention the cost of a total retrim in a thread about speakers otherwise?And yes, i know that you dont need to retrim a car to install speakers in the doors,
As you said, this thread(not forum) is about installing speakers, surely I can have my 10cents worth too?
As I hinted b4, if you aren't going to mount them in the doors, then you are really wasting a lot of time, effort and money doing anything else, the results will be not worth the trouble.
Suggest just go with the centre "radio" speaker(Im assuming there was a position in the standard dash where this was mounted and put a decent one in.....should provide better reproduction than muffled stereo from the footwells and then you can leave the kick panels alone too.)
#30 _73LJWhiteSL_
Posted 18 April 2006 - 09:04 PM
I agree that installing the speakers in the doors is probably the best place sound wise to install them. But if people don't wanna hack up their door trims (and i tell you what i have seen some really really bad examples of speakers installed in doors with the trims just hacked to clear the speakers) then they have to put them in the kick pannels.
To be honest if you really want perfect sound, don't waste your time on a car, a home cinema setup would make you much happier.
For my time and effort i am very happy with the front speaker mounts. I would recommend it to someone who doesn't want to cut their door up, or wants something a little less obvious.
This is a public forum, and i think you are definately allowed to have your opinion, but I think saying that it is a waste of time to install speakers anywhere other than the doors is a bit of a discouragement to those who don't wanna install it in the doors.
Steve
Edited by 73LJWhiteSL, 18 April 2006 - 09:07 PM.
#31
Posted 18 April 2006 - 09:33 PM
#32 _devilsadvocate_
Posted 18 April 2006 - 11:31 PM
That was the idea....dont think Im doing them any disfavours am I? Im sure everyone can come to their own reasoned decision on what is best for themselves.This is a public forum, and i think you are definately allowed to have your opinion, but I think saying that it is a waste of time to install speakers anywhere other than the doors is a bit of a discouragement to those who don't wanna install it in the doors.
Really, Im quite happy with my car and home systems, ....but neither are perfect....but hard to beat. My preferences for sound are that it needs to be good. If it cant be good, then Ill settle for minimum/mediocre and not worry anything in between....just spend as little as possible on the mediocre system to have some noise around. Id either go with the door speakers or just put up with the original radio speaker.To be honest if you really want perfect sound, don't waste your time on a car, a home cinema setup would make you much happier.
Surely this would not be the result if you did it Steve? or is this just an observation that there are people out there that do shoddy work? or you think this task is beyond the average person?(and i tell you what i have seen some really really bad examples of speakers installed in doors with the trims just hacked to clear the speakers) then they have to put them in the kick pannels.
Edited by devilsadvocate, 18 April 2006 - 11:33 PM.
#33 _Flamenco_
Posted 19 April 2006 - 04:14 AM
The main things stopping great sound reproduction (if speakers are mounted in the kick panels) would be lack of volume behind the speakers, suitable positioning because of severe lack of room there (column/wiring/acc pedal and the fuse panel).
I think the way to go might be to mount the speakers in pods in the kick panels but build an extended enclosure from the pod (out of fibreglass) above it underneath the dash so it has enough volume for good reproduction. The size of the enclosure would depend on what speakers were used. Sound deadning inside it would help too...
My 2c
#34
Posted 19 April 2006 - 06:31 AM
If i can find someone with the tools and skill, I'd very tempted to cut a hole into the body behind the kick panel and weld metal pods on the outside (waterproofing). Put the speaker onto an mdf base, screw it into the wall suspended with firm grommets (for breathability). Now the speaker will sticking out just enough to be flat with the kick panel, seated in its natural position No visible external pod, just the speaker facade as you would normally have it.
Edited by smeer, 19 April 2006 - 06:32 AM.
#35
Posted 19 April 2006 - 09:01 PM
RIM
Devilsadvocate, its RIM-010, not RIM-101. Picky, yes, but it loses all meaning if you say RIM-101
How awesome does Gup's HQ look?
#36 _Herne_
Posted 19 April 2006 - 09:14 PM
Herne
#37 _devilsadvocate_
Posted 19 April 2006 - 11:40 PM
Sorry about that Rimolo, oops�. did it again��. RIM-010, perhaps I�ll start a course �rims in trims 101�, �sounds� like there is a pressing hole for it, perhaps i could find my "niche" in life.Devilsadvocate, its RIM-010, not RIM-101. Picky, yes, but it loses all meaning if you say RIM-101
Edited by devilsadvocate, 19 April 2006 - 11:44 PM.
#38
Posted 20 April 2006 - 12:12 PM
Rheers, CIM
#39 _73LJWhiteSL_
Posted 20 April 2006 - 07:40 PM
Not my work. I did install the speakers in the doors of my 76 Mazda 808, but i made new door trims rather than using the the orginal ones.Surely this would not be the result if you did it Steve? or is this just an observation that there are people out there that do shoddy work? or you think this task is beyond the average person?(and i tell you what i have seen some really really bad examples of speakers installed in doors with the trims just hacked to clear the speakers) then they have to put them in the kick pannels.
My earlier attempts at stereo installs leave a lot to be desired, but my later ones are a lot better.
I think quite often people are in a hurry to install stuff, and i won't say that all car stereo installers are shoddy, but there is a small percentage of people who are more interested in getting money than doing a job that will last or is practical.
I don't think it is beyond the average person to install speakers in the doors, however care and forethought is necessary. All it means is measuring and making sure that the speakers fit and that they will have adequat support. And taking your time on the cutting and the installing. Nothing makes a sloppy job like trying to do it in a hurry.
Steve
#40 _Bomber Watson_
Posted 21 April 2006 - 08:16 PM
the material i use is $5.50 a meter. usualy need about 1.5-2 of the base color and a meter or so of the highlight color. i use 6mm foam underneath it, which costs about $20 for enough to do all the doors. costs $10 for a litre of spray adehisive from the local auto trimmers, and if you have to make the trims again costs about $12 for enough masonite to make all the trims. this and a few hours stuffing around is all you need.
i have done some real nice looking doors, heres some picks of some of the ones i have done.
thats my torana with the old speakers
some i did for a mates meteore. the highlighted ford we did by cutting it out in cardboard and gluing it to the trim. then put the foam amd material over it. piss easy.
and in this one you can kinda see the trims in my ute. recognize the speakers
in short with a bit of practice and not much cash you can make your own masterpeices. stuf paying a trimmer $200 to do it.
#41 _Flamenco_
Posted 22 April 2006 - 04:17 PM
#42
Posted 23 April 2006 - 01:54 AM
#43 _Bomber Watson_
Posted 23 April 2006 - 03:21 PM
#44
Posted 24 April 2006 - 09:24 AM
I suppose it depends on the cost of the material your using. By the way what is the material that you have used on your door trims?
#45 _Bomber Watson_
Posted 24 April 2006 - 07:05 PM
