Is there a way to soften up a crashpad vinal?
#1 _jabba_
Posted 25 March 2006 - 10:19 PM
Is there anything i can treat the crash pad's vinal with to make them supple again, if i can make them supple again i might be able to take the warps out of it im hoping!
Damien
#2 _jabba_
Posted 26 March 2006 - 09:35 PM
Posted 01 April 2006 - 09:40 AM
Once the vinyl has dried out it is pretty much had it. A friend of mine used Dubin and a heat gun to try and get some life back into his dash pad. It worked fairly well but you just have to be careful not to apply heat to the dash pad in one area for too long.hrmm, no ideas? Leather conditioner wouldnt bring it back to life, or once there dry and brittle ish there no good anymore? I can press on it and it doesnt crack but it feels very stiff, too much sun.
Edited by antelopeslr5000, 01 April 2006 - 09:41 AM.
#4 _ljbob_
Posted 02 April 2006 - 08:59 PM
BoB
#5 _jabba_
Posted 02 April 2006 - 11:16 PM
#6 _ljbob_
Posted 03 April 2006 - 01:27 PM
BoB
Posted 03 April 2006 - 04:24 PM
Posted 03 April 2006 - 07:49 PM
Posted 03 April 2006 - 08:41 PM
Please tell me you mean "compressed wool" or some other element in a sheep.Lanolin is made from compressed sheep?
#10 _jabba_
Posted 03 April 2006 - 11:01 PM
#11 _Cane_It_
Posted 16 April 2006 - 05:54 PM
dont use solvents on vinyl es ketones (acetone MEK) or esters (ethyl acetate) etc. as they will dull AND PARTIALLY DISSOLVE IT
#12 _jabba_
Posted 18 April 2006 - 07:59 AM
Posted 20 April 2006 - 11:56 AM
Selleys RP7 uses lanolin as the lubricant and WD40 uses silicone - RP7 is the one I prefer.
As for vinyl and plastic, if you notice the dusty film on the inner windscreen above the dash after the car has spent time in the sun that is the plasticisers that have escaped from your interior.
When the plasticisers are released from exposure to sun, heat, time, etc. the material becomes brittle, you can't put them back in no matter what you rub into it.
s
Edited by StephenSLR, 20 April 2006 - 12:01 PM.
#14 _Leakey_
Posted 20 April 2006 - 04:45 PM
With all the mucking about buying RP7 etc, why not look for another dash pad?
Spray it up if the colour is wrong.
Re-vinyling is way too costly, and you wont ever get it to look right
using RP7, WD40, Lanolin, Sheep guts or anything else!!
My 2c.
- Leakey
Posted 20 April 2006 - 08:36 PM
I wouldn't recommend using RP7, WD40, etc. on vinyl, it also has spirits in it that would more than likely dry it out.With all the mucking about buying RP7 etc, why not look for another dash pad?
s
#16 _jabba_
Posted 21 April 2006 - 10:58 PM
#17 _munro_
Posted 22 April 2006 - 01:10 AM
#18 _jabba_
Posted 22 April 2006 - 08:41 AM
Damien
#19 _Leakey_
Posted 22 April 2006 - 04:22 PM
#20 _brett_32i_
Posted 23 April 2006 - 10:15 AM
how good are the dash paints? any one done it and its still looking good???
#21 _jabba_
Posted 23 April 2006 - 10:07 PM
