Hey Neil,
We have been bleeding the brakes on a freinds HQ 1 tonner due to a soft pedal. There was plenty of air in the lines and we bleed through a new bottle of fluid to each of the wheels but after bleeding the air and getting solid fluid flow the air comes back into the lines. There is no leaks in the system so I am mystified to what is causing it.
Any ideas on what it could be?
Cheers,
Air in brake lines
_dags383_
, Mar 26 2006 07:17 PM
3 replies to this topic
#1 _dags383_
Posted 26 March 2006 - 07:17 PM
Posted 26 March 2006 - 11:03 PM
Undo the master off the booster and see if its wet behind. if so m/cyl us. Drawing air through rear seal.
RACV MAN
RACV MAN
#3 _jap-xu1_
Posted 26 March 2006 - 11:07 PM
is the bleed valve on the calipers at the top?
if the calipers are on the wrong side the valve is at the bottom and will cause that prob
Posted 27 March 2006 - 10:52 AM
It may be sucking air back past the caliper seals
