Do I need guide plates?
#1 _bon_scott_
Posted 12 August 2009 - 10:07 PM
Chris
#2 _Brad1979UC_
Posted 12 August 2009 - 10:36 PM
I thought that guide plates were more of an ass cover kind of thing, so if you were to have a very agressive cam they help to keep the rod from possibly straying and damaging anything else if something was to go wrong like it bending, im running them, but you'd have to have the stud holes milled if you wanted to fit guide plates. So it probably would depend on how hot your 6 is but probably not nesessary.
Posted 12 August 2009 - 10:42 PM
I've always run guide plates on all my V8's and 6's with rollers
#4 _bon_scott_
Posted 12 August 2009 - 11:32 PM
#5 _Brad1979UC_
Posted 13 August 2009 - 12:39 AM
#6 _oldjohnno_
Posted 13 August 2009 - 07:21 AM
Be careful, guideplates aren't always an optional thing, sometimes they're essential.
It depends on what head you use; the older style heads that originally used ball-pivot rockers had narrow slotted pushrod holes that guided the rods. There is no need to run guideplates with these heads but if you do you must make sure the guideplate slot and the head slot are perfectly aligned so that there is no binding.
The later heads that originally came with aluminium bridge rocker pivots had a round pushrod hole with lots of clearance. The rocker pivot took care of alignment with these heads. If you use roller rockers or old style ball-pivot rockers with these heads you must use guideplates. Check the alignment when you mock the motor up as sometimes they have to be cut-n-shut to get everything perfectly straight. Also make sure you still have clearance around the rod where it passes thru the head though you should have plenty.
You must use hardened pushrods with guideplates, and also be aware that there is a difference in pushrod length between the ball-mount rockers vs the later ones.
Posted 13 August 2009 - 08:25 AM
#8 _bon_scott_
Posted 13 August 2009 - 12:15 PM
^^^Not quite true..
F**K
That's why I asked though as it seemed like the things would fall off if they were moving around a lot. Seeing as I just got the thing machined for studs, will it need more machining for guide plates?
#9 _oldjohnno_
Posted 13 August 2009 - 01:38 PM
Not necessarily. Obviously the rocker studs will sit a bit higher, but if you still have enough lash adjustment left and the tops of the bosses are reasonably flat and level you should be ok. You could even dress them up with a file if you were careful. If there's any doubt tho machining them should cost bugger-all and is really the way to go.
I forgot to mention that it's only the stud mounted roller rockers that need guideplates; the shaft mounted ones align themselves.
#10 _bon_scott_
Posted 13 August 2009 - 02:07 PM
#11 _mello92_
Posted 13 August 2009 - 03:38 PM
oldjohnno and Dr Terry, please write a book. I'd love to read it.
There, all better.
#12 _oldjohnno_
Posted 13 August 2009 - 08:42 PM
NoWill it worry the studs losing a few threads of grip into the head?
Posted 13 August 2009 - 10:54 PM
#14 _bon_scott_
Posted 14 August 2009 - 12:35 AM
#15 _oldjohnno_
Posted 14 August 2009 - 07:26 AM
You could, but they need to be quite hard so it wouldn't be that simple. The cheapys are only 40 odd bucks so it wouldn't make much sense to make your own.Ok last question, would it be possible to make guide plates myself out of some plate steel? If so, approx how thick, how much clearance do the pushrods need etc, or do they need to be made out of a particular material?
#16 _bon_scott_
Posted 14 August 2009 - 02:52 PM
#17 _monkeyboy454_
Posted 14 August 2009 - 11:12 PM
