RB25DET With Celica 5 speed
#1 _CanberraTorana_
Posted 29 March 2006 - 07:38 PM
are they the best option?
#2 _jap-xu1_
Posted 29 March 2006 - 09:45 PM
the stock rb25 manual is way better than a crappy celica box.
Posted 29 March 2006 - 10:01 PM
"The stock RB25 manual is way better than a Celica box" would have been adequate. A celica box still shits over my M20 and I don't mind my M20, go easy on it
#4 _JBird_
Posted 29 March 2006 - 10:38 PM
#5 _Chaotic_
Posted 29 March 2006 - 11:28 PM
#6 _JBird_
Posted 30 March 2006 - 02:25 AM
that being said try before u buy, and dont buy cheapie rb25's unless youve seen them started etc.
(yeah i noe its late was doing assignment)
#7 _CanberraTorana_
Posted 30 March 2006 - 07:33 AM
are you saying buying a half cut is bad for a rb25????????
Posted 30 March 2006 - 09:20 AM
Thanks.
#9 _CanberraTorana_
Posted 30 March 2006 - 02:55 PM
#10 _jap-xu1_
Posted 30 March 2006 - 04:12 PM
a na vl 5speed would be just as good as the celica box and bolt straight up.
im not being smart or nothing, its just a bad idea.
#11 _CanberraTorana_
Posted 30 March 2006 - 05:14 PM
#12 _jap-xu1_
Posted 30 March 2006 - 05:36 PM
rb25 shares the same 9.5" flywheel as the naturally aspirated (na) vl commodore rb30.
though the 2 gearboxes are very different in terms of strength.
the vl na box(mf5) is a smaller box but it can still take some fair power before giving up the ghost.
the rb25 box is much bigger and is like a newer version of the vl turbo box(mx7).they can both hold huge hp in stock form.
the mx7 flywheel is bigger at 10" and will not fit inside a mf5 bellhousing or a rb25 bellhousing and a different startermotor is used on the mx7.
all rb blocks have the same bolt pattern at the back so all these boxes and more will bolt straight up.
#13 _brett_32i_
Posted 30 March 2006 - 07:27 PM
only advantage i think with celica over rb20/na box is the length.
im using the rb20 (det) for now. put bigger/better bearings in the carrier, shotpeened shafts and gears, so hopefully it will see a couple of hot laps before it goes bang....
then its in with a r154
#14 _dansedgli_
Posted 30 March 2006 - 08:46 PM
Leigh - any ideas how much bigger the R33 box is compared to the NA? Am I gonna have to do the trans tunnel again?
The NA VL box fits in the stock trans tunnel, thats what I have in there now. Its about 2 inches behind the stock spot for the shifter.
#15 _jap-xu1_
Posted 31 March 2006 - 01:32 PM
the actual size of the r33 box is huge compared to the mf5.
ill try and find a pic of my old mx7
#16 _CanberraTorana_
Posted 31 March 2006 - 01:48 PM
