Howdy,
I pulled the booster off to give it a bit of a tidy up and when I was checking it out brake fluid pee'd out of the check valve/vaccum hose? hole. Luckily it went all over my foot and not on the paint work.
I'm assuming this is not normal and suspect a worn/damaged master cylinder has forced fluid back through the rubber seal and into the booster. I will replace both the booster and master but should I be checking anything else ie proportioning valve while I'm at it?
Cheers,
Big T
Brake Fluid in Booster
_Big T_
, Mar 30 2006 07:59 AM
1 reply to this topic
