Need SHOCKS for lowered Torana
Posted 31 March 2006 - 07:03 PM
What companies make shocks for lowered front end?
Posted 05 April 2006 - 06:46 AM
Posted 05 April 2006 - 10:16 AM
my car is low and still uses the standard length shocks, noi matter how low your car is, it should hit the bumpstops before you run out of shocker travel.
Posted 05 April 2006 - 10:55 AM
they seem to do the job when i'm pushin it around the back yard
as i have no engine or gearbox.
Damo
#5 _kaz from adelaide_
Posted 05 April 2006 - 12:02 PM
Spring info
As she stands with 173. Front King Springs KHFL-44 which is the lowered option for 6cyl. Rear King Springs KHRS-12 which is the standard option for 6cyl (rears still need further confirmation tho)KHRL-12 which is the lowered option for 6cyl.
I have discovered the original front springs from ruby can b used for the V8 conversion.
I highly reccommend u check out the King Springs site to comfirm the prior info.
^^^^ copied from my cardomain page.
as for shocks I will have a look asap and c whats in her.
#6 _brett_32i_
Posted 06 April 2006 - 01:12 PM
mine is sitting lower than low in the front at the moment, and no dramas at all with the munroe shocks in there. not even pedders do a lowered for the front, as it s just not necessary.now shock is still 1 1/2" too long to bolt up, once fully compressed, cant use them
as suggested previously, check they gave you the correct shocks???
Posted 06 April 2006 - 02:06 PM
The shocks are just too long.
Posted 06 April 2006 - 03:47 PM
The old discussion will still be around somewhere... but the more I think about it, I think we were only talking about rear end, not front end.
Edited by LXCHEV, 06 April 2006 - 03:51 PM.
#9 _TOBES_
Posted 06 April 2006 - 06:44 PM
You should be able to take the springs out and sit the car on it's bump stops with out the shocks running out of travel.
The bumpstops limit the travel, not the shocks!!!!
I have just minitubbed my VL wagon to fit 275/40-17's on 9.5" rims under the rear without flaring the guards. With the standard shocks the diff dropped down too far and the panhard rod dragged it sideways and jammed the tyre into the drivers side spring perch. A mate at Repco went through the parts book and came up with a set of Munroes with the same compressed length as the std VL and the max extended length I could get away with. They are actually EH rear shocks. They keep the tyre off the spring perch and will also keep the shorter springs captive. I can sit the car on its standard bumpstops and still have travel left in the shocks.
Same story with the front(working on that now), shocks will have the same min compressed length as standard but will have shorter extended length to keep the springs captive.
Ask your supplier to check part no's etc and perhaps ask another company for the Munroe part no as a double check...
Posted 06 April 2006 - 10:47 PM
Maybe they had a stuff up batch or something, I dunno but it shits me now I need to get another set.
#11 _TOBES_
Posted 07 April 2006 - 03:21 PM
He did say the minimum compressed length, measured from the centre of the bottom eye to the base of the top mount pin, should be 216mm. Max extended length should be 336mm.
Interested to see what yours measure???
#12 _2wild4u_
Posted 08 April 2006 - 09:51 PM
#13 _CHOPPER_
Posted 08 April 2006 - 10:51 PM
In theory, that is correct. In the real world, that's another story. I have come across this issue before. Pedders used to sell short shockers, GSR 9000 series from memory. It does sound as if you may have faulty shockers, possibly one of the flow control valves are stuffed. It does happen, and sometimes in batches. How low are these front springs? If possible, I would be driving the car to where you purchased the shockers to demonstrate the problem to them.are you sure that they gave you the right shocks?
