Yeah well !
who knows what will fit the 4cyl 4stud lj
have heard Camira & mini but havent tryed yet
what is a sure fit ?
SWAPS ? 4cyl 4stud ????
_xsteve_
, Apr 01 2006 12:20 AM
5 replies to this topic
#1 _xsteve_
Posted 01 April 2006 - 12:20 AM
#2 _CHOPPER_
Posted 01 April 2006 - 12:28 PM
Camira won't, wrong stud pattern.
Mini won't because they are only 10" in diameter, they won't clear the brakes. If they did, why would you want 10" rims on a Torry? 10" wide would be OK.
Mini Moke rims are 13" and are the correct stud pattern.
Morris Minor will apparently fit. Good luck finding some that aren't rusted to the s#1t house and/or buckeld beyond repair.
#3 _HB1200_
Posted 01 April 2006 - 11:40 PM
So long as its 4 X 4 inch (101.6mm) P.C.D. it will fit. There are alot of cars that have 4 X 100mm P.C.D. They will probably fit and also look right by eye but they wont be correct as far as the propper seating of the nut taper is concerned.
HB1200
HB1200
#4 _xsteve_
Posted 02 April 2006 - 01:43 AM
ok !
no wouldn't want 10" the 12" on it are just that bit small but fine
any other rims anyone ?
#5 _CHOPPER_
Posted 05 April 2006 - 05:50 PM
4x100 PCD WON'T FIT!!!
#6 _Speedy T_
Posted 30 April 2006 - 04:09 PM
Hey guys. I believe the Gemini and Camira wheels will fit, but you have to check the offset. Mini wheels will fit, but 12" or 13" mini wheels that look good are expensive and hard to find. I would go with a set of 13" Gemini mags myself. Hope this helps.
