X-Pipes tech talk
#26
_ass308_
Posted 29 September 2009 - 02:51 PM
its good to hear your x pipe worked out well for u myss427.that must sound sweet with a 3.5 inch system
ls2lxhatch system looks really good too.same principle.i dont know if i could get cats in my system the way it is
i dont like the magna flow one,it looks to bendy.
doctor gas looks good.
just dont get an xpipe with a hole drilled in it to make the x,if u are going to get an x pipe
#27
Posted 29 September 2009 - 02:59 PM
#28
_oldjohnno_
Posted 29 September 2009 - 04:34 PM
#29
Posted 29 September 2009 - 07:01 PM
#30
Posted 29 September 2009 - 07:14 PM
Posted 29 September 2009 - 08:04 PM
This is the Burns Stainless X pipe, see what I mean about the gases crossing from one side to the other rather than just being exposed to the other side. I would imagine this has a better scavenging effect.
Also that DiFillipo pic is a perfect example of poor flow. It might look the part but the overheating at that point is a sure sign of a restriction.
MYSS427, yes Warren did have a twin 4" toward the end there, it ran better with a 4" single than the twin 3" and then better again with the twin 4" but bear in mind it did have more than 500 CID and got turned pretty hard, it was no street car. Also the pipes were totally seperate, no H or X.
My SBC Tonner was using a seperate twin 3 1/2" system. When I moved it all into the HQ Prem it showed more HP and torque with a twin 3" with the home made X.
#33
_LHoon_
Posted 29 September 2009 - 10:45 PM
#34
_NURVUS_
Posted 30 September 2009 - 12:44 PM
The cut on this design needs to be decent so the merge
becomes slightly smaller to create the scavenging effect.
3" pipe, the cut is 200ml long.
#35
_ass308_
Posted 30 September 2009 - 07:55 PM
theres some darn good home made exhaust systems on this forum.
#36
_HRV74_
Posted 07 October 2009 - 10:13 PM
Interesting stuff.
ass308, your new set-up looks tops!
Here's a pic underneath mine. Twin 3's. This made an extra 60rwhp over the previous twin 2.5" system that used a H pipe! However these changes were all done before I owned her, so I can't quote all the variables, such as muffler spec, etc.
Cheers, H
Edited by HRV74, 07 October 2009 - 10:14 PM.
#37
_NURVUS_
Posted 17 October 2009 - 03:50 AM
The old exhaust was 2.5 inch with no crossover pipe at all, 2 unknown brand mufflers and it had some dodgy pressed bends in places. It used to just barely turn the tyres punching second gear with the TH350 on a good day.
It's now 3 inch, mandrel bends and 2 hooker mufflers. After a quick test drive tonight, punching second gear is just plain scarey, and it now turns the tyres in top gear from about 60 or 80km. We expected a difference but not this much and figure a gain of between 60 and 100hp keeping in mind the old exhaust was crap. There is a louder drone inside the car at idle and low revs.. but who cares.... it does top gear skids
#38
_cruiza_
Posted 17 October 2009 - 07:11 AM
#39
Posted 17 October 2009 - 07:19 AM
Just a left field suggestion, but what about a single system, I had a 3" pipe which worked a treat and sounded like a V8 supercar from the early 90s
That is what I'm running now, dual 2 1/2" into single 3 1/2" but I'm not sure if it has helped or hindered.
I do feel the single sounds better though !!!
#40
_user asked to be removed_
Posted 17 October 2009 - 10:33 AM
#41
_beergut_
Posted 17 October 2009 - 08:16 PM
that's what an exhaust shop told me once
#42
_NURVUS_
Posted 17 October 2009 - 08:33 PM
Yeah on a 6 cylinderisn't single for power and twin for sound?
#43
_cruiza_
Posted 17 October 2009 - 09:12 PM
I make no claims to being any sort of expert. All I can do is relate what I had told and why. A chap by the name of Graham Valintine did my exhast setup, Graham was at one point in his career the exhast guy for a formula one race team, so I should say he knows his stuff. He took two days to build a single three inch system for me starting out with twin 4" but flattened to give clearance and while maintening volume under the gearbox crossmember this went down to twin 3" and then to a single 3" with a small custom made box racing muffler and then back up and over a 9" diff all mandel bent curves in stainless.
Ok here are some comments and reasoning on why this was a good design for MY CAR I had 380 - 400 real HP from a 308 V8
There is such a thing as too big, you want a certin amount of gas flow speed to enable siphon effect, also to avoid back eddies in gas flow thru muffler and bends
As the gas flow away from engine they cool maintaning gas pressure flow rates mean that pipe diameter getting smaller can can be a good thing
Gas flow rate, volume of gas and tempture all interrelate so it is about designing system so that as tempture cools pipe size adjusts and muffler is not a sudden change in back presure
A large single pipe has better gas flow then two slightly smaller pipes as there is less surface area of pipe in contact with gas ie 3" single better then twin 2.5"
Oh and smaller pipe after muffler can cause major problems with back pressure in the muffler and have dramic negative effects so if you cann't fit 3" over the diff then do whole system in smaller size
Thats about all I can remmber from what he told me.
#44
Posted 17 October 2009 - 09:27 PM
Just thought I'd add these photos that I finally uploaded. This was the last twin 3" system I had behind my old 4-into-1's. The pics shows the large rectangular balance pipe/tube that I described in my earlier posts.... it seemed to work really well.
