304 + T5 into LX help
#1 _nial8r_
Posted 23 October 2009 - 05:52 PM
Posted 23 October 2009 - 07:48 PM
T700
Tremec TKO600
Tremec TR3550
All these fit without butchering the tunnel
I would have thought the T5 to be smaller
Even Super T10 only needs room made for the shifter not the box
Where does it look tight ?
Posted 23 October 2009 - 08:29 PM
It is my understanding that the Commodore T56 extension housing does not clear the reinforcing hump in the LX torana tunnel. Mal Wood sells a extension housing to suit the T56 into an Torana for around $2400.
I do not know if the same problem applies to the T5.
#4 _nial8r_
Posted 24 October 2009 - 07:05 AM
T400
T700
Tremec TKO600
Tremec TR3550
HI dattoman, thx for the quick reply, the T5 seems to to be hitting the tunnle from just in front of the shifter top plate through to the larger top plate at the front of the box, i cant come down on the motor anymore but im searching for about 50mm more clearence at the top of the box as i only have about 10mm at the moment... i have cut the hoole for the shifter and its all sitting good without making the angle on the uni's to savage !! so all in all im happy with how its sitting now just clearence is my main concerne...
#5 _nial8r_
Posted 24 October 2009 - 01:52 PM
Posted 24 October 2009 - 03:18 PM
#7 _nial8r_
Posted 24 October 2009 - 06:05 PM
Posted 25 October 2009 - 10:25 AM
Posted 25 October 2009 - 10:56 AM
Posted 25 October 2009 - 12:40 PM
#11 _nial8r_
Posted 25 October 2009 - 02:55 PM
#12 _youngy_11_
Posted 25 October 2009 - 05:11 PM
I had problems with the box hitting where you described, when trying to get the shifter up high enough. The guts of it basicaly.
I have been told the Ford T5 is smaller but it looks like its a little too late for that.
Your 304 would sit in a very similar position to the V6 maybe a little more forward but I think you will have to do some tunnel work.
Clearance problems
Heres some photos of the tunnel I had to get fabbed up.
#13 _nial8r_
Posted 25 October 2009 - 05:35 PM
#14 _youngy_11_
Posted 25 October 2009 - 06:48 PM
Did you go to the show at Kembla Grange today?
#15 _LH SLR 3300_
Posted 25 October 2009 - 07:38 PM
Sorry mate, ph no is 03 5472 1442.
Posted 26 October 2009 - 07:46 AM
I'm in the middle of having my T-5 recoed atm.
I sourced a rear extention from the ford T-5, & had the box guru fit it to the commodore box. It brings the shifter forward about 50-65mm, compared to the commy box. The ford rear extention looks visually, slightly narrower.
The ford rear extention fits without further gearbox mods. That was actually surprising! I had expected it to be a huge PIA!
I haven't got my box back yet, or done the trial fit, but i will let the forums know of the result.
#17 _nial8r_
Posted 26 October 2009 - 08:19 PM
Ryan- sry mate i had to be a copy cat on your tunnel mate i had my on thoughts but when i seen yours it looked and seemed so much neater and easyer also thx for all the other info too
Matt- thx for chucking me that number i will have to give them a call if there isnt anywhere local that i can pick up a 304-T5 speedo cable conversion and will have to catch up too
Col- thx for your info too mate but if only i knew the fraud T5 would have done the job sooner but hey there always another Torana to build yet shhhhhhhhhh dont tell the wife
pic's of this arvos effot are posted up in my build thread LX UNDER CONSTRUCTION
thx again fellas
#18 _LH SLR 3300_
Posted 26 October 2009 - 08:36 PM
Posted 09 November 2009 - 12:20 PM
Even the R154 supra box in my other torrie fits without mods and they are a large box!
#20 _youngy_11_
Posted 09 November 2009 - 02:39 PM
#21 _nial8r_
Posted 09 November 2009 - 06:02 PM
#22 _UC_L76_
Posted 13 November 2009 - 07:09 AM
very very suprising rexy ??? got any pic's ??
I think it depends on the T5. I'm pretty sure the selecter housing is shorter on the early model (VK) box. i have heard of some ppl converting a ford T5 to fit as they have a shorter housing as well.
#23
Posted 13 November 2009 - 08:53 AM
Small trim around the back of the standard hole for the shifter - yes, any more butchery than this - no.
The R154 replaced a dead W 55 supra box using a hadfield bellhousing + spacer plate and one of his kit crossmembers. Minor mod to the thrust bearing race plus a few other small odds and ends. It all fit beautifully the first time and has survived nine years and 60,000 kilometers of abuse. If only his hydraulic clutch setups were as painless to get right!
#24 _rammaLH_
Posted 26 November 2009 - 07:24 PM
i had to drop motor in then slide bellhousing and box up and bolt up.
came up fine! had 2 cut hole bigger for shifter to pop through but apart from that all good.
hope this helps, like seeing people doing the same as what im in the process of!
brett
#25 _nial8r_
Posted 26 November 2009 - 07:47 PM
