how do I clean carbies and manifold?
#1 _mike 66_
Posted 03 April 2006 - 05:04 PM
Posted 03 April 2006 - 06:16 PM
Does that answer your question at all?
#3 _dave720gtr_
Posted 03 April 2006 - 07:07 PM
Yes that is exactly what thay do ,, with a very mild acid barth of the carbi bodyHi, Just wondering if it is possible to DIY clean carbies and manifolds? Is there any chemicals that can get into all those small pores in the rough cast aluminium or should this be left to the professionals? If it is what process do they use to clean them, are the manifolds bead blasted? And then are the carbies zinc/nickel plated to make them look new?
#4 _Herne_
Posted 03 April 2006 - 07:23 PM
It will clean the external carby buildup of petrol and oil deposits and supposedly helps clear the jets too.
A word of warning - read the instructions as this stuff is highly flamable when wet.
It works a treat and costs maybe 10 bucks.
Herne
Posted 03 April 2006 - 07:43 PM
For thew DIYer you can use carby cleaner spray.
Posted 03 April 2006 - 07:45 PM
#7 _draglc_
Posted 03 April 2006 - 07:47 PM
A1
Posted 03 April 2006 - 07:48 PM
The manifold is best off being bead blasted.. most engine rebuild shops have a blasting cabinet and should only charge you about $50 or so to do it ( I'm guessing!)
#9 _pipjones_
Posted 03 April 2006 - 07:51 PM
Posted 03 April 2006 - 07:53 PM
#11 _73LJWhiteSL_
Posted 03 April 2006 - 08:51 PM
Steve
Edited by 73LJWhiteSL, 03 April 2006 - 08:53 PM.
#12 _pipjones_
Posted 03 April 2006 - 08:54 PM
#13 _torana05_
Posted 03 April 2006 - 09:25 PM
https://cache.gmh-to...na/IMGP2475.jpg
https://cache.gmh-to...na/IMGP2472.jpg
Andrew 2.
Posted 03 April 2006 - 09:38 PM
RACV MAN
Posted 03 April 2006 - 09:51 PM
Just kidding.. as i said above its very potent stuff... GREAT for getting ingrained grease fron the cracks of your hands while cleaning carbies
#16 _mike 66_
Posted 03 April 2006 - 10:30 PM
