more 253 conversion questions
#1 _kaz from adelaide_
Posted 03 April 2006 - 10:38 PM
I have also been told that keeping the column shift trimatic i am going 2 have 2 change the manifold i use because the V8 manifold doesnt fit with column shift trimatic???? I was told 2 use standard manifold.!?!?!
just a reminder this work is being done on Ruby (LX) currently running a 173 i will b keeping the brake booster that is on her now, but if its too scarey then I'll change later.
p.s sorry about the april fools 'for sale' thread, but i knew it would spin a few heads.
#2 _kaz from adelaide_
Posted 07 April 2006 - 11:34 AM
#3 _CHOPPER_
Posted 07 April 2006 - 07:36 PM
#4 _Loki_
Posted 10 April 2006 - 10:17 AM
For the love of god, please don't.i will b keeping the brake booster that is on her now, but if its too scarey then I'll change later.
When it comes to safety thing's like brakes, don't be a scimp and scrounge/save money.
If you can't afford to buy/reco a v8 brake booster, you can't afford this conversion!
#5 _kaz from adelaide_
Posted 10 April 2006 - 11:26 AM
#6 _Loki_
Posted 10 April 2006 - 11:37 AM
In short, the booster makes pushing the pedal to the floor easier/pushing the brakes on harder easier.Loki I have been told the 6cyl booster is enough 2 cope with the V8. Is this not right???
The more weight you ahve the harder you have to push the brakes to stop (and therefore harder before they lock up as well).
The booster makes using the brake pedal easier to apply the correct amount of pressure to the pads.
It's simply a safety thing to upgrade the booster.I'm not entirely sure but I also thought it was a registration legality.
My golden rule is simply: if it's related to stopping or safety, don't @#$ bguck around, ghetto mod anything or take the cheap shortcut, it's not just your life, it's your passengers, other road users and pedestrians.
And sure, of course its "enough" to stop the car, you can roll down a giant hill with the engine off, and even without the power assisted brakes it's still "enough" to stop, doesn't make it safe or easy though.
Edited by Loki, 10 April 2006 - 11:39 AM.
#7 _kaz from adelaide_
Posted 10 April 2006 - 12:04 PM
I will c how we go once engine is in.
#8 _BlownOutlaw_
Posted 14 April 2006 - 09:46 AM
Have also converted 6cyl to V8 keeping the original braking system. Had no problems.
Leigh
