heya guys
got myself a supra box and it comes with a hydrolic clutch. the bloke didnt give me a clutch pedal for it.
this is what it looks like , that attaches onto the firewall.
i was thinking of sumthing like a standard LX rat trap pedal type setup. , cos didnt they have a rod pushy thing?
thanks guys
Evan...
What clutch pedal do i need for this clutch? Pics
Evan
, Apr 04 2006 03:22 PM
3 replies to this topic
Posted 04 April 2006 - 03:22 PM
#2 _TORANR AMORE_
Posted 04 April 2006 - 03:54 PM
You need a bracket that holds the master cylinder in some obscure angle and a rod that goes from the pedal to the inner of the master cylinder thatg you're holding in the photo. The pedal is a normal pedal with a extra bit welded to it towards the bottom of the pivot so that it pushes the rod, which will be at an angle of almost 60 to 70degrees or something. the rest is positioning the bracket that the master cylinder bolts onto, which is where I'm at a bit confused as to exactly where It should go on the firewall.
This pic although not a good one shows some of the stuff you need
a here's a link to another thread on Hydraulic Clutch setup
http://www.gmh-toran...ydraulic clutch
Although, if you have an existing rat trap setup in your car, this should work ok for a supra box
Hope this helps
Hope this helps
Edited by TORANR AMORE, 04 April 2006 - 03:56 PM.
Posted 04 April 2006 - 04:00 PM
thanks amore
i dont have a rat trap setup atm , i converted to commi cable type.
im pretty handy with the welder so ill have to give it a go making my own stuff up.
Evan...
Evan...
Posted 04 April 2006 - 04:07 PM
by reading that other poste, it may be easier to go for the old cable clutch.
i drive my bothers RX7 and i dint like the hydrolic clutch. couldnt really feel the bite point.
Evan..
Evan..
