triple su quick questions
#51 _oldjohnno_
Posted 15 November 2009 - 04:21 PM
The exact quantity and type of oil isn't really critical despite what everyone says, just don't go any thinner than ATF or much thicker than 20W engine oil. I usually just stick the same oil in that I run in the engine. Generally SU's have very sharp response if they are tuned and have oil in them.
#52 _brendan_h_
Posted 15 November 2009 - 04:24 PM
On the top of the carb will be a screw cap, probably black plastic. Screw this out, it'll have a rod and a piston attached. This piston fits in a tube that rises and falls with the carb slide. With the air cleaners removed lift the slide to the top with your finger and then squirt some oil in until it's about 10mm from the top of the tube. It'll only take a teaspoon or so of oil.
just to double cheak. life the piston up all the way then fill it with oil from the top of the dashpot in the tube?
#53 _oldjohnno_
Posted 15 November 2009 - 05:03 PM
#54 _brendan_h_
Posted 15 November 2009 - 05:18 PM
#55 _oldjohnno_
Posted 15 November 2009 - 05:34 PM
#56 _brendan_h_
Posted 15 November 2009 - 06:11 PM
#57 _oldjohnno_
Posted 15 November 2009 - 06:33 PM
#58
Posted 15 November 2009 - 07:09 PM
http://images.google.com.au/imgres?imgurl=http://www.chicagolandmgclub.com/techtips/general/pics/147.gif&imgrefurl=http://www.chicagolandmgclub.com/techtips/general/549.html&usg=__XJ-jIwA7KjqpUjTYas5_Yzw4L1A=&h=139&w=150&sz=9&hl=en&start=15&sig2=lx_S1wrj8O4IK3m0dH1Ajw&um=1&tbnid=culhAcUqTnOZsM:&tbnh=89&tbnw=96&prev=/images%3Fq%3Dsu%2Bdamper%2Boil%2Bpictures%26hl%3Den%26lr%3D%26rlz%3D1G1GGLQ_ENAU326%26sa%3DX%26um%3D1&ei=_pz_SrSyL4-Y6gPXh8nbCg
You might have missed this link on page 2 as Johnno and I posted at the same time?
It explains what the oil/damper does and it's effect on acceleration.
#59 _brendan_h_
Posted 15 November 2009 - 07:39 PM
thanks for telling me this
#60 _oldjohnno_
Posted 15 November 2009 - 08:01 PM
#61 _brendan_h_
Posted 15 November 2009 - 08:03 PM
Can't say I've ever taken any notice, but I wouldn't worry too much - it might be just a bit of air trapped in there. I'd just take it for a run to see how it goes. If you're worried about it tho I'll grab a set from the shed and see if they do the same thing.
that would be great if you could do that.
apart from oil the only thing left is a decent throttle. so what does everyone use?
#62 _oldjohnno_
Posted 15 November 2009 - 08:27 PM
OK I just tried a couple and it does seem a little easier to lift at the top of the stroke - might just feel like that tho cos it's easier to pull up on it when it's up high. Anyway I wouldn't worry too much there's really nothing there to go wrong..
Go for a wander around the local wreckers and you'll soon find a suitable pedal. As for cables I've been known to use $5 pushbike brake cables from kmart and they've been fine. You might want to get some lighter return springs too - the std SU one is ok on a single carb but with triples you'll end up with huge calf muscles in yr right leg.
#63 _brendan_h_
Posted 15 November 2009 - 08:34 PM
yer think i might on next weekend. its currently has a pusgbike cable throttle but i dont like it. i want to get a proper one. ive got the return springs that came with the redline linkage kit. the they are too heavy to be practable
#64 _brendan_h_
Posted 16 November 2009 - 05:40 PM
#65
Posted 17 November 2009 - 07:02 AM
#66 _brendan_h_
Posted 17 November 2009 - 07:53 AM
Ok so should i get an early commodore? Or the hq will be alright?HQ was a lever arrangement similar to the LC/LJ Torana. UC Torana fits ok, or most early commodores.
#67 _brendan_h_
Posted 17 November 2009 - 12:56 PM
#68 _threeblindmice_
Posted 17 November 2009 - 03:31 PM
If your worried about slowing down the rise,your in the wrong gear !
Edited by threeblindmice, 17 November 2009 - 03:36 PM.
#69 _brendan_h_
Posted 17 November 2009 - 07:11 PM
#70 _threeblindmice_
Posted 17 November 2009 - 07:21 PM
#71 _brendan_h_
Posted 17 November 2009 - 07:37 PM
Some of my mates used sewing machine oil .
yer was going to try air tool oil, whichc is basicly the same shit. how would i get the oil out of the dashpots?
#72 _mello92_
Posted 17 November 2009 - 07:40 PM
Or you could find your local stockist for Penrite to chase this one up: http://www.penriteoi...l/su_damper_oil
Repco here put it in the too hard basket, but you may have more luck.
Failing that, ATF fuild is ok.
To get the oil out of the dampers, the only practical way I can see is to remove the 3 screws that hold the suction chamber on, then CAREFULLY remove the piston, being careful not to bend the needle, and tip it out. Clean it out with a rag to remove the rest of it.
If you put the same piston and suction chamber combo back on the same carb, I cant see how any settings are going to be affected.
Remeber to put oil back in them.
Edited by mello92, 17 November 2009 - 07:46 PM.
#73
Posted 17 November 2009 - 07:41 PM
Undo the chamber off the carby body.how would i get the oil out of the dashpots?
Carefully lift the piston assembly out and tip the oil out.
#74 _oldjohnno_
Posted 17 November 2009 - 08:25 PM
Edit: If you really want to experiment with different oils (and you'll end up back at a 15 or 20 weight anyway) just hold a rag over the top and blow the oil out with an air hose.
Edited by oldjohnno, 17 November 2009 - 08:29 PM.
#75 _brendan_h_
Posted 18 November 2009 - 07:06 AM
