gday all,
I have been given a blue 202 crank for my red 202 build up from a mate, But another mate has told me the rear main seal is different between the reds and some of the blues. He told me the reds all had rope seals and some of the blues had rope seals and some nyeprene. Can someone confirm or deny this?
Also how would i spot the difference?
Steve
Are All Blue Cranks The Same?
_73LJWhiteSL_
, Nov 24 2005 12:49 PM
5 replies to this topic
#1 _73LJWhiteSL_
Posted 24 November 2005 - 12:49 PM
#2 _draglc_
Posted 24 November 2005 - 01:04 PM
not sure which ones had what, but the rope seal is just a bit of rope, pretty easy to spot. The neoprene is a hard rubber seal. Youll see if u pull the engine apart.
#3 _WYLDLC 6_
Posted 24 November 2005 - 02:19 PM
Steve Ive got the same setup in my LC, and from memory my engine builder told me to use a block, from a HQ-HZ as they used the rope seal.
Hope this helps.
Hope this helps.
#4 _73LJWhiteSL_
Posted 24 November 2005 - 03:52 PM
I got the crank out of a VH that a mate had.
I guess it is the not rope seal.
Steve
Steve
Posted 24 November 2005 - 04:02 PM
doesn't matter because there is a neoprene seal that can be fitted to rope seal blocks now...I found out from the local engine reco dude so i am gussing a trip to a similar establishment may yeild results...unless your local repco/bursons/autobarn/whatever are clued up (mine usually are not) then they may know about it..I have a red 202 with a neoprene seal and if I can get the part no. of it I will post it here.
#6 _rorym_
Posted 24 November 2005 - 04:28 PM
In the Perkins/ACL rebuild kit we had it had both in it. Check the kits.
