hey so a few months back I bought a S/b chev fuel pump and I was going to put it on my 186 the other night so I pulled my old pump off and compared them. the holden 6 fuel pump was alot ( I mean alot) easier to depess by hand than the S/B chev one. I know a few other guys on here have used them but I was worried it my put to much stain on the motor ( cam) and maybe bugger something? any help or advice would be good
also would I be better to run a electic fuel pump instead?
cheers antony
S/B fuel pump on a 186
_superlowuc_
, Apr 07 2006 04:54 PM
8 replies to this topic
#1 _superlowuc_
Posted 07 April 2006 - 04:54 PM
#2 _high_rpm_
Posted 07 April 2006 - 05:05 PM
electric would be the better option
Posted 07 April 2006 - 05:07 PM
Obviously Luke's right there. Any chance of the fuel pump being a bit better if you pull it apart, clean it out, oil it up and stick new gaskets through it?
I can't imagine it straining the engine too much. Keep in mind how much momentum the internals of an engine have, especially with metal timing gear. I suppose it would be an issue if it started grinding into the cam a bit, but it's quite unlikely.
Edited by Heath, 07 April 2006 - 05:09 PM.
Posted 07 April 2006 - 06:13 PM
I woudlnt think that there would be any problem with the pump being harder to depress.
Only go electric if there is another reason to. Rember the KISS principal, if it doesnt need the complexity why do it!
The cam wont have any more pressure on it with either pump.. I wouldnt be worried about it!
Posted 07 April 2006 - 07:37 PM
Hey guys,
What is the advantage of putting an S/B Chev fuel pump on a Holden six?
Regards Matt
Regards Matt
#6 _Bomber Watson_
Posted 07 April 2006 - 08:00 PM
yeah mate, my pump is very very hard to depress by hand. shouldent be a drama though i recon
matt, they flow more fuel. thats about it.
#7 _superlowuc_
Posted 07 April 2006 - 09:51 PM
thanks again guys, I will put it in on the week end and see how it all goes
cheers antony
cheers antony
Posted 08 April 2006 - 08:59 PM
If you think the pump is hard to push try pushing down on a valve spring !!! And the cam has to open 12 of those !!
The fact that the pump is hard to compress is a good thing...... The firmer spring is to stave off "valve float". This is why most fuel pumps run out of fuel at high RPM, inadequate spring pressure.
Posted 08 April 2006 - 09:16 PM
Not contradicting any of the above but if you have any doubt, blue, black pumps are bigger than standard 186.
