G'day all,
I've come to a standstill with my T5 conversion.
Some of the bearing faces on the input shaft have breakages in the machined surfaces. They cant be felt with a finger.
I am thinking that i might be able to skim a couple of thou off the worn surfaces, build back up with powder spray, then re-linish to size.
Has anyone done this, or is there a flaw in my cunning plan?
I have full access to a machine shop, & am currently chasing down contacts in the metal spraying game, so the labour content will be minimal. Certainly cheaper than spending $400 on a new input shaft.
Anyone done metal powder spraying?
, Jan 14 2010 01:14 PM
8 replies to this topic
Posted 14 January 2010 - 01:14 PM
Posted 14 January 2010 - 02:21 PM
I damaged the front of a crankshaft when the harmonic balancer worked loose and had it repaired this way.
It was 100% successful.
Cant see why it wouldnt work for your application.
Posted 14 January 2010 - 06:07 PM
Could you explain this process breifly?
Posted 14 January 2010 - 06:22 PM
metal is applied using a fine tipped heating torch with a hopper on top. Similar to a gravity fed spray gun.
The metal is in powder form.
Preheat the item, rotate at a constant speed, apply the spray powder with concentrated heat.
My concern is that the preheat might be above the plastic limit of the parent metal.
Posted 14 January 2010 - 07:30 PM
Kinda like a one-step Powdered Metallurgy process, cool. Cheers!
#7 _Bomber Watson_
Posted 14 January 2010 - 08:37 PM
Col, did you consider putting a coat or two of braize around the damaged areas then re machining to size???
Guys have done this at work a few times, i thought it was dodgy as hell but has held together in the trucks just fine.....
Probably quicker, easyer, and less heat, thats all.
Posted 14 January 2010 - 10:09 PM
I have considered shrinking a bronze bush in the internal.
Posted 14 January 2010 - 10:23 PM
Wonder if that would work on the flange...
