Hello,
Can anyone tell me if there is any difference between a V8 Holden flywheel and a V8 Chev flywheel?
Do they both have the same bolt pattern?
Cheers Paul.
Holden - Chev flywheel
its Paul
, Jan 24 2010 09:13 PM
7 replies to this topic
Posted 24 January 2010 - 09:13 PM
Posted 24 January 2010 - 09:20 PM
For the clutch yes
For the crank no
For the crank no
Posted 24 January 2010 - 10:15 PM
Thanks Neil,
Would it be safe to assume that all Holden 355 stroker cranks are Chev pattern?
I sent my flywheel away to be lightened (new flywheel) and it didn�t dawn on me to check to see if it fitted until it was gone.
My engine had a 350 turbo behind it but have since sold it with the flex plate so I don�t have anything to measure other than the crank and nothing to compare it with, do you or any one else know what the measurement of the crank bolt holes are for a Chev? I know that the flywheel is for a Chev as it came from the states with my gearbox.
Any help will be greatly appreciated.
Cheers Paul.
Cheers Paul.
Posted 24 January 2010 - 10:29 PM
I can go out to the shed and measure the flexplate holes on my Chev for you
But I'm betting the 308 is way different
Posted 24 January 2010 - 10:45 PM
Thanks Neil, that would be great if you could, If its not getting to late.
Posted 24 January 2010 - 10:54 PM
I measured approximately 46mm hole centres
Posted 24 January 2010 - 11:33 PM
OK
I checked both the Chev plate and a 308 plate
The Chev is larger... but its a 168 tooth unit (about 1" larger)
Theres also a 153 tooth unit thats smaller... probably the same diameter as a 308 one
The Chev plate has 6 holes all spaced evenly... yes they are about 46mm hole centres (not diameter of pcd)
The 308 has the same centre hole size and 6 bolt holes
But 5 are the same (46mm) and one hole is closer to one side... so the plate can only go on one way
I'd doubt 355 stroker cranks would be Chev pattern.... they would be 308 style
Posted 25 January 2010 - 07:48 AM
Thanks for that,
I have 6 holes and one of them measures about 48mm which makes it closer to the edge, so now I am looking for a new flywheel.
Thanks for your help Datto, much appreciated.
Cheers Paul.
Cheers Paul.
