engine starting problem.. SU's
#1 _draglc_
Posted 10 April 2006 - 09:00 PM
engine specs:
202 + 40thou, flat top pistons, blue rods, nitrous cam .238 & .248 @ .50, 1.6 inlet & 1.5 outlet ratio roller rockers, big $$ 186 YT head big valves, screw in studs and guideplates, straight cut gears, triple 1.75 HIF SU's, 2.5" exhaust, elec dizzy and splitfire 8.8mm leads, carter electric fuel pump.
Now the problem. I can crank the car over for a minute, before my battery starts to die, but the carbs dont get any fuel. They are the HIF design, with the integrated fuel bowl. I let the carter pump go for 5 seconds, then try to start and it will splutter once, then just turn over for ages, and ages, until it starts to get fuel. But thats usually after my battery dies. If i spray a shitload of 'Start ya bastard' down the pcv into the manifold, itll fire, and run dodgily and eventually get going, though it sounds like its running on 5 cylinders.
The carbs were tuned a month or so ago, but they do need another tune, but i dont think thats the problem. They DO have oil in them, singer sewing machine oil.
The timing is set at 14 degrees advanced, could that be the problem with a high compression engine (10.5-1)? If the engine is warm/hot, it will start instantly. Its only when its dead cold that i have this problem, ie in the mornings, and in the arvo when i try to go home from work.
Can anyone suggest a solution?
#2 _Herne_
Posted 10 April 2006 - 10:01 PM
Just a thought.
Herne
Posted 10 April 2006 - 10:05 PM
Posted 11 April 2006 - 07:00 AM
If not, what I do when its been sitting for a while is open the jet on the bottom of the carb and put a clothes peg on them to stop then closing
It then starts easy, as soon as it start put the pegs off and start as normal.
Dont give it a rev with the chokes open as the needle can get stuck on the top of the open jet and cause all kinds of problems.
Loui
#5 _draglc_
Posted 11 April 2006 - 08:28 PM
A1
Posted 11 April 2006 - 08:46 PM
Loui
Posted 11 April 2006 - 10:37 PM
Give that a go and see how it turns out. It worked on my old Datsun 1200 !!
#8 _draglc_
Posted 12 April 2006 - 02:35 PM
A1
Posted 12 April 2006 - 03:35 PM
Also if it has a big cam it may be low on vacuum at crank. (The fuel is there but not getting sucked into the combustion chambers) Also with the timing at 14 it probably is cranking a little slow. Maybe back it off to 10?
Good luck!
Edited by rodomo, 12 April 2006 - 03:37 PM.
#10 _draglc_
Posted 12 April 2006 - 05:38 PM
A1
#11 _uglybob_
Posted 12 April 2006 - 07:59 PM
Posted 12 April 2006 - 10:40 PM
#13 _revmaniac_
Posted 17 April 2006 - 08:36 PM
i personally would try to get in the habit of holding the acc pedal down when turning the engine off so some fuel gets sucked into the manifold in that last few seconds... either that or "teeing" your fuel line and fitting a soleniod (same as the ones used in duel fuel cars) between the "tee" and the manifold so that before you crank the engine you can let the electric pump prime the system then a short press of a button would open the solenoid and spray a bit of feul into the manifold...
hope you get her sorted
Posted 18 April 2006 - 07:43 AM
