hawks uc sunbird
#651
Posted 15 December 2014 - 09:04 PM
#652
Posted 16 December 2014 - 06:03 PM
You are doing well,bloody big job when it all starts
The lower part of the radiator support panel is as weak as piss.
After replacing the rusted sections i added this.
Very simple and does not take away from structural integrity and can be removed easily if needs be.
"rabbit proofing" the uc.
rp.JPG 38.5K
3 downloads
#653
Posted 06 January 2015 - 03:16 PM
#654
Posted 07 January 2015 - 10:29 PM
Nothing wrong with solder and heat-shrink mate
#655
Posted 08 January 2015 - 01:09 AM
Ditto ^^ as long as its done properly soldering is fine, in fact I'd much prefer soldering to crimped joints because crimped joints are too easy to pull apart (as you've found out!).
#656
Posted 08 January 2015 - 01:01 PM
Also got another grinder just hope it lasts longer than the last 3 haha. Also transferred the rego to vic and is now regoed for another year. Might try and make tfest this year if funds allow
#657
Posted 09 January 2015 - 02:34 PM
Yep. I have a proper crimping tool and they still come off sometimes. Wherever practical I prefer to solder - much more secure. When I have to crimp (for jobs that require pull-apart connectors rather than a permanent connection) I fold the wire over so that the crimped fastener has more to clamp on to. If you can't get the wire through when it's bent double then twist it around in a tight spiral - makes it fatter.
Edited by Steve TPF, 09 January 2015 - 02:35 PM.
#658
Posted 10 January 2015 - 06:13 PM
They do reckon never solder a crimp connector but have done heaps and no problem so long as the wire is not just hanging.
Just use minimal heat to make the join secure so that the solder don't run back down the wire too far.
The folded wire in the crimp end works pretty well too.
Take your time with it and you won't have a problem...
#659
Posted 16 January 2015 - 05:36 PM
finally an update. sorry about the pics as they might not be in order.
first up I started welding bits in trial and error pretty much and I did a pretty poor job of a few repairs so am currently redoing them.
I dropped the motor in for a bit so I could sort out the wiring and where I want things to run, then today I pulled it all out again to start
redoing the poor repairs.
also had my alloy radiator turn up and bought a rare spares alt bracket.
Posted 17 January 2015 - 01:16 PM
#661
Posted 17 January 2015 - 01:30 PM
#662
_Lazarus_
Posted 17 January 2015 - 02:12 PM
Looking great hawk, good on you for taking a hands on approach with everything.
#663
Posted 17 January 2015 - 02:31 PM
I wanted to remove the bumps where the washer bottle attaches to the inner guard but im worries ill stuff it again so might just weld up the screw holes and leave the bumps.
#664
_mick74lh_
Posted 17 January 2015 - 06:42 PM
Loving your work Steve.
#665
Posted 17 January 2015 - 07:55 PM
thanks heres some pics also mucked around with my donor hinge plate.
it looked rust free until I separated the backing plate, so to anyone who thinks there is no rust behind there hinges I recommend reving the backing plate to be sure and using a good sealed in there when reattaching it.
ill be checking behind the apparent rust free bonnet hinge section on the passengers side just to be sure now.
and with the large section in, its all done other than three pinholes after grinding them back but ill get to that tomorrow if I have time.
Posted 18 January 2015 - 09:45 AM
#667
Posted 19 January 2015 - 08:03 PM
Im not overly confident with my welds but thay may just be because im using gassless wire at the moment.
Im considers completely lipping the chassis rails, removing the heater box, removing the lumps in the wheel arches and smooth battery tray and carbon cannister areas.
Is it worth it? And could a beginner manage doing it? Also what would i do with the chassis number? What have others done with theres?
#668
_Lazarus_
Posted 20 January 2015 - 10:09 AM
I wouldn't myself, to any car.
Tidy up the wiring, stick the battery in the boot and paint everything nice.
Cars are for driving.
#669
Posted 20 January 2015 - 01:49 PM
The first step to improve your welding is to remove that flux-core wire, take it to the top of the highest hill around and let it roll... I'm yet to see a decent MIG weld made without gas and after all, MIG stands for Metal Inert Gas welding, it's not really a "MIG" without gas!
It's just a shame that hiring a bottle of Argoshield is so expensive, if you're doing a lot of welding it's well worth it but if you only use the welder once a month it gets mighty expensive to have sitting around.
Once you get setup with a bottle, flow regulator and the correct wire, next give the tip and nozzle a good clean to get rid of any and all spatter that's built up.
Then grab some scrap steel and have a play around with the voltage and wire feed, they aren't "set and forget", you will find you need to constantly trim the setup depending on whether you're welding something thin and rusty or thick and solid, after a little while you'll get good at guessing a starting point and maybe not blow so many holes in whatever you're welding.
I also recommend watching a YouTube video or two on technique, MIG is counter-intuitive to stick welding and different again from TIG.
Also, do some destructive tests on your practice welds, clamp one side in a vice and see if you can break your weld, then grind it flush with the metal surface and see if you can break it again. A decent weld should be as strong as the metal around it and if finished properly only distinguishable by the discolouration (and not even then if you go to the trouble of heat-treating).
Then it's just a matter of practice, practice, practice!
I wouldn't recommend you tackle anything structural like chassis rail work until you're confident
#670
Posted 20 January 2015 - 07:49 PM
Also after heaths advice of not usimg a flap disc to clean the welds has helped a lot im still having trouble getting a good finish. I thin the metal too much in places and it causes issues any more advice?
#671
_GMH-001_
Posted 20 January 2015 - 08:19 PM
Don't use heavy hands, let the tool do the work. Much easier to see/stop when needed. Keep tool (grinding disc etc) as flat to the panel as you can. It will spread the load over a larger area and result in a more even finish with less 'digging in'
#672
Posted 20 January 2015 - 08:26 PM
#673
Posted 20 January 2015 - 08:31 PM
Its now known as GMAW, or Gas Metal Arc Welding, as there are some processes used now that use an active gas.
But everyone still calls it MIG.
Pedantic, but true.
#674
Posted 20 January 2015 - 08:55 PM
They perform much better than flapper wheels when used correctly.
80 grit works fine.
There are rubber ones around, but these SAIT units are far superior to them.
Keep it flat when you use it and take it slow.
Keeping it flat lets it act like a sanding block and you will only knock off the high spots. (which is what you want)
Don't let the metal get too hot, either.
The discs go blunt quickly when they overheat and just skate over the high spots instead of knocking them down.
They last a lot longer if you take it easy, as well as doing a much better job.
Discs cost around a buck each.
#675
Posted 20 January 2015 - 08:56 PM
