LC Upgrade
#1 _Lokky Moore_
Posted 12 April 2006 - 10:50 AM
I figure I will need to get a hold of a 6 clinder firewall to nosecone (a sedan would do I'm guessing) The 6 cylinder crossmember/suspension etc. And I'm hoping I could use early holden axles and diff for the ass end.
Have I completely missed the plot and this is going to be a ridiculously major operation. Or is it possible and can somone point me in the right direction and how to go about doing what I want to do.
#2 _lx5008_
Posted 12 April 2006 - 01:15 PM
#3 _Lokky Moore_
Posted 12 April 2006 - 01:45 PM
The other thing I forgot to add was that - for a stocky red will I need to chassis strengthen? Or am I going to have to do it anyway for blue plate?
#4 _high_rpm_
Posted 12 April 2006 - 02:10 PM
Posted 12 April 2006 - 02:18 PM
You would be much better off finding a clean, complete 6 shell and salvaging what you can off your existing 4. All the interchangeable bits, glass, rubbers, interior, rear drive-train etc. And it wont be much more expensive than welding a front-cut.
If you found you would be replacing nearly everything during the 4 shell restore, you just confirmed that you made the right decision to get the new shell.
Edited by smeer, 12 April 2006 - 02:21 PM.
#6 _xsteve_
Posted 14 April 2006 - 02:36 AM
drop the six in to it with the stubby front left on
i would love another 4 cyl
Posted 14 April 2006 - 05:06 PM
Grant..
Posted 15 April 2006 - 08:23 AM
Edited by shanegtr, 15 April 2006 - 08:24 AM.
#9 _Lokky Moore_
Posted 15 April 2006 - 12:07 PM
My major hassle and the part that I'm trying to figure out most is the legalities. I think QLD you can have a 15% (?) upgrade without haveing to get safety mods. The 173 would be more than 100% which is why I want to do it
Legally for blue plate I'm assuming that I'll need to upgrade the brakes and stud patters hence the assumption about the cross member and ass. CAn anyone point me in the right direction as a how too? I'm sure its been done before so hopefully someone has already done the hard work
enderwigginau where would I find the info on the gemini mods?
Posted 17 April 2006 - 03:21 PM
#11 _Hmmm_
Posted 17 April 2006 - 04:00 PM
His words were to get a red six in; LC/LJ crossmember incl relocated mounts, anti crush tubes, chassis kit with modifications, upgrade diff, and a dirty great hole in the firewall. To replace this cut section means an overlap of about 1inch with swaging wherever possible. No change to the front clip, per se. Addition of crossmember provides many benefits to the installation, not limited to just no need to create engine mounts.
Big job, but it has been done before. If you have the tools, this is how to do it.
#12 _Lokky Moore_
Posted 17 April 2006 - 04:30 PM
Greatly Appreciated.
Cheers Lokky
