13" tires
#26
Posted 05 March 2010 - 07:37 PM
Those interested please for a queue
peter
#27
Posted 05 March 2010 - 08:48 PM
oh well will just have to wait for next lot.
peter
#28
Posted 05 March 2010 - 08:53 PM
Just let me know what you need and we'll work it out
You still have some hubs I want back and maybe that intake box too
#29
Posted 05 March 2010 - 09:59 PM
bugger missed out. Got out bid with 3 seconds to go, by a bidder that only made one bid!!!!!!!!.
Pete, I could be wrong but it sounds like you don't know how to use ebay effectively, you're not alone many people still don't understand how it works.
Bid the highest amount you would pay for the item then walk away, if you are there till the last three seconds bidding furiously it's like gambling, you get competitive and could end up bidding more than what you wanted to spend.
The guy that won bid once and he could've been the first person to bid. He bid the highest amount he wanted to pay for it and nobody outbid him at closing.
Let's say an item is currently at $1 it's worth no more than $10, and you were the very first person to bid, you could in theory bid $1,000 for the item.
You will not get charged $1,000 unless someone else pushes the bid that high, of course nobody will for a $10 item.
If the highest bid for that item at closing is $5 you will win and only pay the next increment, so you will end up winning the item for $5.50 or $6 (depending on the increment) even though you were the first person to bid and placed only one bid of $1,000.
s
#30
Posted 06 March 2010 - 05:43 PM
I understand how it can work but there is also the thrill of the chase!!!!!
So I missed out this time there will always be a next time. I wasn't willing to go over $650 for the wheels as a new set is less than $1000. So not much sense getting too carried away and getting too close to the price for a new set when the used set have to be crack tested and checked for roundness before I can use them.
peter
#31 _torbirdie_
Posted 07 March 2010 - 06:40 AM
Interestingly the quoted list only gives the pcd to the nearest mm, possibly with the european cars they are exactly 108mm. We dont know whether they could indeed be the correct size for the torana which is 4.24? or 4.25? in, or 107.7 and 108.0mmIts 2 thou difference...not quite the same as trying to fit Astra wheels which have 2mm (80 thou) difference....or Commodore on HQ which are 0.6 mm or approx 23.5 thou different.
If its 4.24 is within 0.30mm good enough?
Another factor to consider is the bore diameter, which I assume possibly tells you whether the rim will fit over the holden hub and/or need additional locators. What the chart doesnt also tell you is the bore diameter of the stud holes , and whether you'll be able to get nuts which secure it properly to the torana threads.
Edited by torbirdie, 07 March 2010 - 06:43 AM.
#32
Posted 07 March 2010 - 08:18 AM
4.24 is a nothing size....I don't care how many books misprinted it.
4.25 inches is an exact size.
108 mm is an exact size.
If you check out the link to the original page...it has some bore sizes on it...I didn't feel like cluttering up the table with another number..esp after the formatting stuff up.
#33 _torbirdie_
Posted 07 March 2010 - 09:48 AM
Fair enough, 4 1/4 indeed sounds more likely.4.24 is a nothing size....I don't care how many books misprinted it.
Has anyone really measured it accurately on a torana hub, what do the wheel makers use? or were the manufacturing tolerances beyond the difference making it a non issue anyway?
#34
Posted 07 March 2010 - 01:07 PM
#35
Posted 07 March 2010 - 07:48 PM
Datto, cold air box is put to one side, Hubs, we can talk about.
What's the suggestion... hit me with it.
#36
Posted 07 March 2010 - 07:50 PM
#37
Posted 07 March 2010 - 07:53 PM
Do you know someone who makes cold air boxes?
s
#38
Posted 07 March 2010 - 10:16 PM
Mine was supplied by a Mate of REDA9X, not sure if he would have any more
Datto, the question was brakes, what else can we do?
#39
Posted 07 March 2010 - 10:27 PM
Do we have to do anything... surely your not outdriving them
We could play with compounds if your after more cold bite
#40
Posted 10 March 2010 - 12:50 PM
Hrrrm, I assume you're not bidding on the torana parts that I watch.........any $10 torana part is sure to go for $50 because too many people wanna talk their stuff up.....
Grant..
#41
Posted 10 March 2010 - 06:21 PM
If the bid starts at $10 it will only go for $50 if others bid that high.
If the item is worth $10 and the seller puts it in for $50 people tend not to bid for it at all if it ain't worth it.
s
