304 5L Build- thoughts and opinions wanted
29 replies to this topic
#1 toryman76
toryman76
  • 1,082 posts
Posted 03 March 2010 - 12:55 PM
G'day guys,
I have just acquired a 304 5L for my LX Torana project and it is in need of a bit of a freshen up.
Things I know about it is that it has done around 250,000km's and has never been pulled down, so as far as I know its stock bores.
I am thinking of getting it rebuilt to pretty much stock specs with maybe a nicer cam, but I'm after your guys thoughts. I am only planning on putting a aussie 4 speed behind it and not looking for some radical streeter, just something nice and strong.
So I guess this is a post for your suggestions as well as recommended engine builders to get the job done.
Anything in the north-west region of Melbournes suburbs would be good. (I live in Riddells Creek just near Sunbury)
Cheers in advance
Leigh
#2 toryman76
toryman76
  • 1,082 posts
Posted 10 March 2010 - 01:16 PM
Surely 1 of the 50odd viewers can heed some advice? :spoton:
#3 Potta
Posted 10 March 2010 - 01:49 PM
I'm only looking because I might be doing the same thing and know very little about these motors.
#4 rexy
rexy
  • 3,741 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 10 March 2010 - 05:17 PM
Is it a good running engine?
If so from your description of what you want I would fit it as is, do all the sorting required and see what you do and dont like. Then when you decide to rebuild/upgrade you will have a clearer idea of what to do.
If you want a standard cruiser with an aussie 4 speed do the minimum now. I will suggest it is probably easier to fit a T5 or other box at the start rather than after you inevitably break the 4 speed, plus its a bit of rooting around to fit up to the turbo pattern block.
Like most of us you will probably want more power out of the 304 after a while....
#5 _ass308_
_ass308_
Posted 10 March 2010 - 06:38 PM
how much money do u have,or do u wana spend ?
#6 toryman76
toryman76
  • 1,082 posts
Posted 10 March 2010 - 06:54 PM
rexy - I have never had the engine running but when purchased I was told it was a good runner. I deliberately bought this engine because it is a trimatic pattern so I could bolt up the 4 speed gearbox I already have.
ass308 - I was hoping to spend around $1500.00
#7 76lxhatch
  • 7,209 posts
Posted 10 March 2010 - 06:55 PM
Sounds like a good plan to me, exhaust and a mild cam but otherwise stock will be a nice engine and will go plenty well enough in an LX.
I agree about the 4 speed being more much hassle than its worth though, mainly because of the block pattern.
#8 _gmlj6_
_gmlj6_
Posted 10 March 2010 - 07:38 PM
nitrous
#9 _LH SLR 3300_
_LH SLR 3300_
Posted 10 March 2010 - 07:52 PM
$1500 should get you the parts you need to do a basic rebuild on a 304 including rings, bearings, a decent cam, lifters, timing chain, oil pump, gaskets etc. It won't cover machining, new pistons, fitting pistons to gudgeon pins etc if the engine needs to be over bored as well. Even on a stock engine rebuild i always get the heads serviced, so i recommend doing this too.I bolted a pair of heads untouched onto a re-ringed 304 once only to pull them off again because a few valves weren't seating properly causing the engine to lose compression on a couple of cylinders.
#10 _LH8VD69_
_LH8VD69_
Posted 10 March 2010 - 07:55 PM
Mate since the engine is going to be stripped down you are better off keeping the car off the road a bit longer and saving the few extra $$ to do a half reasonable job otherwise you will be cheesed off after a little while n wish you did. Nothing crazy just some head work, decent cam,zaust,use qaulity valves, piston n rings ect and to cut down the revs and be a better cruiser go the 5 speed box. Just my two bobs worth :)
#11 xu1kid
xu1kid
  • 364 posts
  • Name:anthony
  • Car:lj gtr xu1
Posted 10 March 2010 - 08:05 PM
my mate did his vs 5 litre engine up just put flat top pistons new bearings and bit bigger cam still hydraulic stock heads it made around 200 hp at the wheels it wasnt bad to drive, that little bit more compression made it much better to drive, in the end its you choice
#12 _gmlj6_
_gmlj6_
Posted 11 March 2010 - 06:01 PM
nitrous
#13 TerrA LX
Posted 11 March 2010 - 11:55 PM
Hot tank, rings, bearings and a decent head job won't go astray.
#14 _TJ253_
_TJ253_
Posted 12 March 2010 - 10:04 AM
So if u ran a 5.0L what would be a good gearbox to put behind it and what could u get on a $1800 budget
#15 TerrA LX
Posted 12 March 2010 - 06:42 PM
If you like overdrive then just about any 5 speed you can get behind a bellhousing under budget will do you unless you drive it stupid.
Edited by TerrA LX, 12 March 2010 - 06:43 PM.
#16 rexy
rexy
  • 3,741 posts
  • Name:Rexy
Posted 12 March 2010 - 08:41 PM
I think your budget is very small for any sort of reasonable gain to be had by stripping the motor, even assuming you did all the assembly yourself.
Get it together and running, spend some of your money or reusable good bolt ons for the next step up if you really want to and keep saving your pennies until you have a reasonable budget for a performance oriented rebuild.
Good luck with it.
#17 _gmlj6_
_gmlj6_
Posted 14 March 2010 - 05:49 PM
rings bearings flat tops and nitrous
#18 yel327
  • 13,682 posts
Posted 15 March 2010 - 04:32 PM
If it's an original trimatic pattern 304 it must be from a VK or VL, so it'll have early heads. What do do depends upon the condition of the bores and the mains. As a minimum with 250,000kM and if original I'd say from experience you'll need:
Pistons, rings, bearings;
Hot tank, bore, hone, crank grind;
New welch plugs and cam bearings;
Heads serviced, silly not to fit hardened seats, may need guides;
New cam, lifters, adjustable timing set;
New oil pump;
New gasket set.
I'd also get the rods resized and new rod bolts fitted.
If you are really lucky it may just need a hone and new rings, and a crank linish and new bearings. The rest of it will pretty much still have to be done. It may also need a new water pump.
Stick an Edelbrock Performer and rebuilt Quadrajet on it all all will be sweet. If it's a carbied 304 it should already have a HEI dizzy on it.
#19 toryman76
toryman76
  • 1,082 posts
Posted 16 March 2010 - 07:53 PM
I was told it was from a VL (engine no. prefix VJ) and believe it was carbied. No accessories came with the engine however I do have a electronic dissy lying around just not sure how to identify it.
yel327 - do you have a rough estimate of what all that might cost?
If anyone has any good reliable contacts for rebuilding engines I would love for you to share them with me :-)
Leigh
#20 _gmlj6_
_gmlj6_
Posted 17 March 2010 - 08:15 PM
i think all it wants is a whole mess of nitrous. it wont go any slower
#21 toryman76
toryman76
  • 1,082 posts
Posted 17 March 2010 - 09:00 PM
your comments are useless.... No where have I mentioned anything about wanting nitrous
#22 _gmlj6_
_gmlj6_
Posted 18 March 2010 - 05:05 PM
u never said u didnt want it either mate.
#23 _Brad1979UC_
_Brad1979UC_
Posted 20 March 2010 - 01:49 AM
ugh ... :wtf: ....
Anyway...mate i reckon you'll be fine with the M20...i dont know that your budget warrants any other box but an M20 will hold up they get downplayed alot, sure there are many better boxes, but they are a cost effective solution (you've already got one!)...dont forget you'd need to change the input shaft and retainer shaft.
VJ prefix denotes it was out of a VL, which is carbied, and has EGR ports on the heads.
personally tho, no offense but $1500 wont get the job done, it will get 'a' job done, but its not worth it, i like the sound of your setup but i think the work you've got cut out for this motor realistically is more like $3k worth buy the time u get it all sorted.
That said r.g. baker engineering in Box Hill south do fantastic machining and head work...they're listed under our businesses section.
#24 toryman76
toryman76
  • 1,082 posts
Posted 23 March 2010 - 09:39 AM
New oil pump;
New gasket set.I'd also get the rods resized and new rod bolts fitted.
I have begun to speak to some workshops and to get something like this done (which they all seem to say is a basic rebuild) and for this and a compression increase I'm looking at around 3-4000. So there goes the budget! haha. I do want to do the job properly as I hate cutting corners.
Brad1979UC - What is the difference with the carbied heads and the EFI ones?
#25 _Brad1979UC_
_Brad1979UC_
Posted 23 March 2010 - 08:32 PM
EFI heads have different exhaust ports...they are evenly spaced rather than the earlier style with the pair in the middle. Not sure if the inlet is the same or different id say its the same. There may be more differences than just exhaust ports but im not sure, but i guess to modify the casting they would have re-engineered he head to a degree.
Yea $3-4k seems alot more reasonable. Do as much work as you can yourself if you can, its rewarding and you save $. Some things (like heads) id rather just give to a trusted shop though, [i had bakers mill and tap heads for roller rockers, new valves, seals & valve seats, (they were already ported and polished)]
