LC GTR rear suspension bushes
#1 _gtr161s_
Posted 14 April 2006 - 06:12 PM
They look arkward as they are pressed through the sides of the arms.
Any tips would be good
#2 _rorym_
Posted 14 April 2006 - 09:11 PM
Posted 14 April 2006 - 10:36 PM
I used a press with these bits of cut up pipe but if you don't have one, you can either belt them in with a hammer or weld end plates onto these pipes and use 1/2" threaded rod with some nuts if you don't want to damage paint etc.
If you are in Brissy, you can even borrow these ones if they are boomerangs.
M@
Edit: If you weld the plates on the end of these and use the threaded rod as I describe above, it is the perfect tool for doing the ones in the diff housing too.
Edited by Toranamat69, 14 April 2006 - 10:40 PM.
#4 _gtr161s_
Posted 15 April 2006 - 03:51 PM
#5 _gtr161s_
Posted 08 June 2006 - 07:39 AM
Every rear suspension ive seen on the lc/lj's had out of shape rear bushes.
Its going to feel like new in the rear end!!
Posted 08 June 2006 - 04:49 PM
#7 _munro_
Posted 08 June 2006 - 05:18 PM
you only need to hit once unless it's really tight
tom
Posted 08 June 2006 - 11:05 PM
Matt
Posted 09 June 2006 - 12:14 PM
#10 _Oldn64_
Posted 09 June 2006 - 12:18 PM
Correct Makka. At worst use urethane in teh bottom. but rubber in the top. If you do not the diff will be solid and say hello to uncontrolable rear end.it will handle better with some rubber in it, I think its the uppers that you use the rubber in or else it binds.
#11 _gtr161s_
Posted 09 June 2006 - 03:24 PM
LC's and LJ's were'nt reknown for there comfortable ride so why make them harder.
My LJ back in '87 still had its old holden rubbers and handled beautifully, i tried the urethane option when they were all the rage and found it to stiff and hard.
Posted 09 June 2006 - 04:12 PM
I ran all polyurethane in my rear end and after about 10,000K's the upper front bushes both split right through as the polyurethane cannot flex enough for the range of suspension travel. I can take a photo of them if you want - I stumbled across my old arms last weekend when cleaning up.
It will also effect your handling too (in a negative way) if the bushes do not allow it to move through it's range of travel. The car will be trying to lift the inside rear wheel on a turn.
Compliant rubber bushes are delibrately used for this reason when they originally designed the things.
For a pure drag car, poly would be fine all round.
M@
#13 _Oldn64_
Posted 09 June 2006 - 04:50 PM
Execpt for the pure loss of traction that a stiff rear end will cause, Not to mention axle tramp as the diff tries to tear itself out of the car, very similar to the example of the one above. I would not use nolethane or any cheapo product when it comes to suspension. Even my sway bar up teh front only runs harderned rubber in the radius rods. the link D bushes are the standard rubber. Some give is good. It means things do nto bend and have a chance to last.For a pure drag car, poly would be fine all round.
#14 _gtr161s_
Posted 10 June 2006 - 01:34 PM
Both were distorted out of shape and wouldnt return to there original form whereas the other original gmh rubbers were worn out but still remained the same shape.
Says alot for urethane type rubbers!
Keep the original feel.
