VS Commodore issues.
50 replies to this topic
#26 _beergut_
_beergut_
Posted 12 March 2010 - 10:53 PM
body control module just to be different lol
#27 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 12 March 2010 - 11:11 PM
^I've never had one of these go on me, but have done the CAS in every commodore I've had. :dontknow:
#28 _mello92_
_mello92_
Posted 14 March 2010 - 08:04 PM
We tried and tried, but couldnt get that damper off.
But the C.A.S. cost us $80.
Sooo......lets give it to someone else to fix, eh? :D
Cheers for the help fellas, that 'cool it down with water' trick works a treat.
#29 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 14 March 2010 - 09:45 PM
You need a big 3 jaw gear puller. That's what I use anyway.
$80 for a CAS? Faaarrrrk....
#30 _mello92_
_mello92_
Posted 14 March 2010 - 09:55 PM
Yeah I big a*se puller, but the problem is getting the bolt undone.... Posted Image
#31 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 14 March 2010 - 10:06 PM
I put a big arse breaker bar on the bolt and the other end on the chassis rail and kick the engine to crack it. But a bit of pipe on a normal ratchet would work as well.
Just make sure it's on the correct side of the engine bay to undo the bolt, not tighten it...
#32 _mello92_
_mello92_
Posted 14 March 2010 - 11:08 PM
LOL, I had that thought! But was afraid Id break something!
Oh wait! I did! :D One SWG 1/2" breaker bar. Cracked the head off it. Lifetime warranty means a new one for free. :D
Dont diss the SWG stuff though. That 1/2" socket set has been through hell and the only thing that has broken has been the bar. Maybe because there was a piece of pipe on it......... :)
I still use my Sidchrome anyday. :D
#33 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 14 March 2010 - 11:52 PM
Yeah I've only done it with a breaker bar that reaches the rail. Dunno where I got it from but it's come in handy.
#34 _robrenjus_
_robrenjus_
Posted 15 March 2010 - 01:18 PM
[/quote]
no matter which way you put the breaker bar you cannot tighten the crank bolt unless you can get the motor to spin backwards lol. but if you face the handle toward the drivers side you may risk it flying off and hitting the bonnet or something. plus ive replaced a bazzillion of those C.A.S and sometimes those bolts are very very tight (rattle guns often struggle ).good luck
#35 _wayneo_
_wayneo_
Posted 15 March 2010 - 02:01 PM
another thing that could be wrong is the cam angle sensor, i replaced my crank angle sensor twice thinking that has to be it and it was a cam angle sensor WTF, its hidden away behind the water pump. god i use to love it every morning breaking down on the way to work in nearly the same spot everyday, pull over have a smoke or 2 then she would run again!!
#36 _mello92_
_mello92_
Posted 15 March 2010 - 03:21 PM
Its ok fellas, the car has been booked into a mechanic so he can sort it out.
I did have a go with the rattle gun first, it obviously didnt work either.
#37 _wraith75_
_wraith75_
Posted 15 March 2010 - 09:27 PM
$80 for a C.R.S FARRRRRK had a look at work on saterday and there $56 .
#38 _mello92_
_mello92_
Posted 15 March 2010 - 09:33 PM
Im not complaining.
You need the part.
You dont care what it costs.
Its that simple.
#39 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 16 March 2010 - 12:06 AM
[quote name='robrenjus' date='15 March 2010 - 01:18 PM' timestamp='1268623125' post='490219']
[/quote]
[/quote]
Good point. That's just me not thinking. :P
#40 _Gunmetal LH_
_Gunmetal LH_
Posted 17 March 2010 - 05:32 PM
If you have too much in the way to rest the breaker bar on a chassis rail, put the handle of the bar near the ground. Turn the power steering pump over with a screwdriver till the slack is taken up at he bar. Crank it for like a 1/4 of a sec. May take 2 or 3 goes to get it to budge.
DO NOT get a mate to hold it in position!
#41 _mello92_
_mello92_
Posted 17 March 2010 - 07:45 PM
LOL, easy fellas, its been fixed! :)
#42 _robrenjus_
_robrenjus_
Posted 17 March 2010 - 08:56 PM
AND.... WAS IT THE CRANK ANGLE SENSOR??
#43 _mello92_
_mello92_
Posted 17 March 2010 - 10:06 PM
WELL THE CRANK ANGLE SENSOR HAS BEEN REPLACED BUT I HAVENT TESTED IT YET SO I DONT KNOW IF ITS SOLVED THE PROBLEM.
MY BROTHER SAID THAT IT WAS FINE WHEN HE DROVE IT HOME!!
:P
hahaha, enough caps for one night!
#44 _mello92_
_mello92_
Posted 25 March 2010 - 04:17 PM
To update - the car has been fine until this afternoon.
Didnt start again, when hot. Posted Image Poured 2 litres of water over it and away I went.
#45 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 25 March 2010 - 06:45 PM
warranty job on the sensor...it should come apart easy enough for you to do now.
#46 _Woodsy_
_Woodsy_
Posted 25 March 2010 - 07:03 PM
you done the paperclip test?..
#47 _beergut_
_beergut_
Posted 25 March 2010 - 07:12 PM
check for cracks in the wiring mate did all the above to a friends vn and traced it to this
although a match and a rag works on every crummydoor i've ever seen lol
#48 GML-31
Posted 25 March 2010 - 07:18 PM
sure the plug to sensor just isnt corroded and making connection dicky?
#49 _mello92_
_mello92_
Posted 25 March 2010 - 07:37 PM
Josh - no I havent sorry.
Kev - I dont know, I didnt replace it, on the check list though.
Will have a poke around this weekend. Have got some time, I think.
Thanks again lads.
#50 rodomo
  • 18,060 posts
Posted 25 March 2010 - 07:49 PM
Have a read of this thread Mello:
http://www.gmh-toran...=0
A couple of other things to try are swapping the fuel pump and e.f.i relays with ones that have done less work (e.g horn relay) if every thing in the c.a.s. circuit is o.k.
