CRACKING IN PRIMER
Posted 24 March 2010 - 06:00 PM
Posted 24 March 2010 - 07:08 PM
Ima need a whole lot more info, tell me EXACTLY what you did, and i may be able to tell you where it went pear shaped.
_beergut_
Posted 24 March 2010 - 07:15 PM
but bomber will set you on the right track
Posted 24 March 2010 - 07:16 PM
POOR PREPARATION!!!
Posted 25 March 2010 - 07:42 AM
[attachment=7174:PrimerS (2).JPG][attachment=7175:PrimerS (3).JPG]
And knowing my friend who did this, "it was nothing wrong that he did."
Edited by Orleans, 25 March 2010 - 07:54 AM.
Posted 25 March 2010 - 08:56 AM
_nial8r_
Posted 25 March 2010 - 08:59 AM
Posted 25 March 2010 - 09:07 AM
Finish should be reasonably smooth, perhaps a tad peely, in acrylic, not look like 36 grit sand paper. Obviously you have been using to fast a thinner and/or holding the gun to far away and/or not enough volume.
The crack can only be for a couple of reasons really, first the primer has been put on to thick and cracked as it shrunk, and second the primer was put over an unsuitable substrate.
With acrylic i would lean toward the second. Now its time to play 21 questions.
Was the primer under it the same type?
Was the brand of spray putty (horrid horrid shit) the same brand?
What was the spray putty (horrid horrid shit) put over?
Are you using spot filler? If so what brand/type?
What drying times have you been giving everything, IE
between coats,
before sanding,
with spot filler how long have you been letting it flash.
Has any filler been put on the car then allowed to get wet (rain etc)?
Has the primer been alowed to get wet(rain, etc)?
When wet rubbing (not recommended until final prime) have you been working on one area at a time then drying it before going onto the next?
Answer all those questions and we may have a solution for you.
Posted 25 March 2010 - 01:46 PM
Im stil going with preparation.
In the picture above, did it crack over a seam or joint?
Posted 25 March 2010 - 05:57 PM
As I first said, I don't think there was enough thinners used.
Q &A
--Yes, From the same can.
--Yes, same brand.
--Sanded back acrylic paint.
--Haven't used any yet.
between coats. --Days.
before sanding. --Days.
--No (cracks are not where filler is).
--No. Car is garaged.
When wet rubbing (not recommended until final prime) have you been working on one area at a time then drying it before going onto the next.
--Havn't wet rubbed yet.
Thanks for helping Bomber (it's funny you say Spray putty is horrid shit - my mate (panelbeater) loves it!) Think I'll continue on without him. I'm a mechanic. I've never sprayed anything before!
Posted 25 March 2010 - 06:27 PM
_beergut_
Posted 25 March 2010 - 06:39 PM
remember to prepsol it and clean the s#$t out of it
and if it cracks again then you have enamel/2 pack/silicone somewhere
oh and remove alll your silicone based products to another shed
aycrillic HATES sillycone in any form lol
_Pete_
Posted 25 March 2010 - 09:59 PM
It's not a slur on the bloke who put it on, we've all gotten a bit carried away from time to time particularly when your trying to build up/make good on crap panel work given to you by overrated panelbeaters....sorry for the rant....it's just accidental, it can be feathered out until its stopped lifting/cracking and spot primed to rectify it.
Posted 25 March 2010 - 10:12 PM
& some flakeing on corners and crevices etc.
_gtr161s_
Posted 27 March 2010 - 11:32 AM
_beergut_
Posted 28 March 2010 - 05:32 PM
rub it back prepsol it(solvent based wax and grease remover is now detergent based)
wipe it off with a tack rag and reprime
and buy a good compresser and spray guns those airosol things end up costing more to do a whole car
Posted 29 March 2010 - 07:39 AM
Edited by Orleans, 29 March 2010 - 07:40 AM.
_beergut_
Posted 30 March 2010 - 09:44 PM
Posted 30 March 2010 - 10:03 PM
I just got back from my melb trip, i'll comment on the actual problem when im sober and have re read all the replies a few times.
_freddy_
Posted 31 March 2010 - 07:51 AM
wen i had probs with primer sum other panels i found out i was usein the wrong thinners them was told to thin at 4 parts primer to 1 part hardener but the primer had thinners already in it from where i brought it.
#21
Posted 31 March 2010 - 12:24 PM
This pic below is one of the cracks around the boot channel. The other cracks were in the door sills.
[attachment=7238:PrimerS (3).JPG]
I've sanded them back to bare metal. Hoping they don't reappear...
Oh, I fired my friend John, who was painting my car for me. Now I hope I don't frOck it up from here on in.
Have no experience with a spray gun... but I should by the time I've finished this project!
#22
Posted 31 March 2010 - 12:54 PM
_MR LJ 1972_
Posted 02 April 2010 - 09:39 PM
#24
Posted 02 April 2010 - 09:59 PM
Your reasons for Peel are correct but not the only ones, there are about a hundred more, and although yoru correct that acrylic doesnt stop shrinking for three months it NEVER actually cures.....
Etch is a good idea over bare metal, but do you know why?
And we ARE talking about Acrylic here....
#25
_MR LJ 1972_
Posted 03 April 2010 - 06:39 PM
Yep, you seem to know a tiny bit about painting, bugger all about 2k's, and not much of whats going on here. I made nothing out of that post...
Talking about Acrylic, cause the thread actually started regarding a problem with ACRYLIC PRIMER. (check the thread starter)
Sorry about the detail, it must of got confusing for you, totally understood what was going on in the thread and yes you are right there are many more reasons for peel and cracking, fry up, delamination etc.....etc...... O'h your also right about me knowing a tiny bit about painting, i have been doing it for about 18 years, both Acrylic and 2k, Etch primer is not mandatory but it does provide very good adheasion to bare metal surfaces and reduces the risk of fry up in the paintwork when it's applyed over a repair for following coats . In the panel shop which i am head painter we have both systems cause people who want their resto jobs to look original choose Acrylic rather than 2k.
and besides don't we join forums for a chat and maybe to help someone out because they share a similar passion, cause that's what i thought. Not to have forum cowboys have a half assed crack at putting you down. when your trying to help someone out.
