Edited by meanmachine72, 03 April 2010 - 06:49 PM.
Posted 03 April 2010 - 06:46 PM
Posted 03 April 2010 - 06:52 PM
Sorry about the detail, it must of got confusing for you,
Posted 03 April 2010 - 06:56 PM
Posted 03 April 2010 - 08:07 PM
bomber 26 posts is that a PB???
This is only caused by a few reasons, 1. some one has painted a 2 pac clear over acrylic to escape buffing (this is ok to areas not exposed to extended UV light), 2. too much hardner is mixed into 2 pac clear or excessive base coat colour coats will cause clear coat to delaminate causing the clear to peel.
Edited by Bomber Watson, 03 April 2010 - 08:08 PM.
Posted 03 April 2010 - 08:35 PM
Sorry man thats confusing to. No idea what your on about?
Posted 03 April 2010 - 10:57 PM
Edited by Yella SLuR, 03 April 2010 - 10:58 PM.
Posted 04 April 2010 - 01:02 PM
hi patI reckon Bomber and Pete are spot on.
The only other time I've had this, is where it disolved the old paint, or I'd cut through it on the edge of a panel, and slipped under some old bog where rust had formed under it from not being keyed in properly. That was a weird one off though.
Had to sand it back, which lead to discovering the old bog.
I've also had weird effects with tack rag residue and acrylic primers. I changed to tack rag first, followed by a wipe down with wax and grease remover. I used to tack rag last. Fixed that problem.
Ranting....
Edited by brocks72xu1, 04 April 2010 - 01:02 PM.
Posted 04 April 2010 - 01:37 PM
Posted 04 April 2010 - 02:15 PM
That makes two of us mate. Thanks for the heads up on that one Brocks72xu1.I....i have a habit of putting them back in there bags.
Posted 07 April 2010 - 03:49 PM
That is where i got confused, what does that have to do with Acrylic primer cracking, which is what the thread is about?
But, im usually the last person to get up someone for grammar/punctuation, god knows im no good at it. So seeing though thats basically what it was i APOLOGIZE (In big bold letters so no one can get up me for trying to hide it), as i should have asked you to clear up your post before saying anything.
Peace.
