Is an Alloy cage in a Street car a bit wanky?
53 replies to this topic
#1 _UCV80_
_UCV80_
Posted 16 April 2010 - 09:32 AM
I have a 4pt Cage in my UC and I'm starting to think weather or not its a bit wanky to have one in a street car and especially because its alloy and not steel.
I put it in my car back when I was about 19. I'm thinking of either getting rid of it or painting it black to blend in and maybe some thinner foam.
What do you guys think about alloy roll cages in street cars?
#2 _Skapinad_
_Skapinad_
Posted 16 April 2010 - 09:34 AM
I think it depends on the car.. I quite like them on older cars, but newer or small 4cyls look a bit out of place imo.
ohh and the car needs to be pretty bloody quick (whether the cage would be effective in a crash doesnt matter). As long as a taxi cant smash ya off the lights... !!!!
Edited by Skapinad, 16 April 2010 - 09:36 AM.
#3 dattoman
  • 16,473 posts
Posted 16 April 2010 - 09:52 AM
Affirmative,... wanky
Howard has an alloy cage
But it was put in 20 odd years ago when it was a period mod and thats what was available
Steel for me
#4 MRLXSS
  • 12,396 posts
Posted 16 April 2010 - 10:04 AM
I think its more cop-bait that wanky... Thats the main reason i wouldn't run one in a street car.
But painted black and hidden is more acceptable.
#5 Statler
  • 6,282 posts
Posted 16 April 2010 - 10:37 AM
Some people think it's a wank. But i think some people are wankers....so it kinda levels out! :)
I prefer to think of them as cheap insurance.
I had a 1/2 alloy cage in this.... Posted Image
Clearly the accident wasn't our fault, but i believe the cage was the only thing that stopped ^ from becoming a whole lot worse! The impact moved the nosecone around on the bolts about 3-5mm! It was only a 60kph shunt! Without the cage, the parcel shelf would have bent a lot more than it did.
I originally installed the cage because of the sunroof. Bloody glad i did!
So....i've seen the benefits of having a 1/2 cage in a car.
I never hesitated in installing a 1/2 cage in the next car.
Is it a wank???.....i dont think so!
#6 ls2lxhatch
  • 5,332 posts
Posted 16 April 2010 - 10:44 AM
If the cage is not ANDRA or CAMS approved then what is its purpose?
#7 myss427
myss427
  • 1,636 posts
Posted 16 April 2010 - 11:20 AM
I was told by tech standards 20 years ago to have a cage or they would not register it. Now they will not if you have a cage, things change! All I could get back then was a BOND alloy cage, still there.
Edited by myss427, 16 April 2010 - 11:21 AM.
#8 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 April 2010 - 12:01 PM
What difference would the material make as to whether or not it's wanky?
I's always go the alloy regardless to keep the weight down.
s
#9 Heath
  • 18,322 posts
Posted 16 April 2010 - 12:51 PM
^ Because of strength mate. They don't even certify alloy cages any more.
Each to their own, I don't think it's a wanky thing, but I guess I might be a bit of a wanker. Regardless it's much better than a non-functional bonnet scoop hehehe
#10 _UCV80_
_UCV80_
Posted 16 April 2010 - 01:02 PM
Cheers for the comments
I think ill pull it out and paint it satin black and get new padding,
The picture above is some serious damage, It is a good safety thing. I think it helps a little with chassis twisting too.
I cant do 10's so i guess alloy is ok. steel is needed to do sub 11's that's why the material changes things
I do have over 400hp so a cage would be acceptable
Paint and padding should fix the problem
#11 ls2lxhatch
  • 5,332 posts
Posted 16 April 2010 - 01:12 PM
The only reason an alloy cage could be considered "wanky" is because it is no longer considered suitable as a safety device by ANDRA or CAMS.
Painting it black will not change that.
#12 GML-31
Posted 16 April 2010 - 03:41 PM
do yourself a favour Nathan and get it powder coated satin black, wont scratch as easy.
#13 _AD_75_
_AD_75_
Posted 16 April 2010 - 04:06 PM
The only reasons in my mind to have a cage are if you have a street registered car that needs to meet the Andra or Cams racing guidelines, or if using it in conjunction with a car which has a chassis kit fitted to help strengthen the car against chassis twist from a serious engine combo. In both cases if you have a car that is capable of falling under both conditions it should have at least a half cage fitted for your own personal safety in case you do one day stack it..any other reason for having a cage fitted is purely for show or "wank factor"
Edited by AD_75, 16 April 2010 - 04:09 PM.
#14 _UCV80_
_UCV80_
Posted 16 April 2010 - 05:34 PM
Great idea Kev, ill have to get it powder coated. Im redoing the whole interior soon and want it all real nice. Has lots of wear and tear from the last 4 years. Cage is probably good too since ill have a baby seat in there.
Looks like my cage wont be wankey after all, I have no need for an ANDRA or CAMS approved cage.
After its coated, whos to know its alloy.
#15 rodomo
  • 18,001 posts
Posted 16 April 2010 - 05:45 PM
Anything would be better than nothing as Col has pointed out.
#16 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 April 2010 - 05:50 PM
So in a roll-over are they just cosmetic?
I don't understand the concept totally, having them in the rear do they protect those in the back seat moreso or is the half cage enough to keep the front pillars from crumpling?
s
Edited by StephenSLR, 16 April 2010 - 06:01 PM.
#17 _Herne_
_Herne_
Posted 16 April 2010 - 06:14 PM
s
I don't think that half roll cages in street cars are a wank assuming the car has some performance features.
However I don't honestly think those rear braces attached to the parcel shelf would offer much protection if any and could possibly make things worse.
I have a half cage here for my car but as yet unfitted as I am still trying to work out exactly where I will run the rear braces to.
Has anyone modified a half cage so as it mounts somewhere where it might actually do some good???
Herne
#18 Heath
  • 18,322 posts
Posted 16 April 2010 - 06:46 PM
StephenSLR, the idea is that your head is pretty close to the B pillars, so if you strengthen up the B pillar area, then you can roll the car and the front of the car isn't going to dip down so low that your head is exposed. Just like in convertibles will rollbars (doesn't matter if they have a windscreen or not as that just shatters, same as in a sedan), always behind the occupant's heads, preferably quite close
My racecar will have a half cage that doesn't mount to the parcel shelf.
And AD_75, you don't need a 'serious engine combo' to benefit from modifications to improve chassis rigidity, but points like that seem to get lost on a forum where everyone is just into straight line racing. :mellow:
#19 _Yella SLuR_
_Yella SLuR_
Posted 16 April 2010 - 11:56 PM
Without any triangulation, and no helmet, they are just something to bump your head on. Wouldn't have much strength at all. Bit like a boom on a sailing boat (that's the noise it makes when it hits you in the head).
Edited by Yella SLuR, 16 April 2010 - 11:57 PM.
#20 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Location:Adelaide... city of... anyone know something good about it?
  • Car:UC hatch
Posted 17 April 2010 - 11:59 AM
I may need a roll cage in the hatch - but not for "wank" factor. There's rust in the roof that will at some stage need to be cut out. This will make the car unroadworthy, but if I remove the rear sets and fit a roll cage I'm hoping it could get approved. Without the rear seats and with no parcel shelf it should be possible to fit a decent, functional roll cage.
Viroads guidlines say a cage is permissable as long as it doesn't endanger the occupants. With no rear seats the only danger areas are the front bars if I fit a six-point - permissable if I follow guidelines and pad the bars.
Anyone fitted a cage for this or similar reason?
#21 _Bomber Watson_
Posted 17 April 2010 - 01:45 PM
Do the repair properly so its perfectly legal?
#22 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 17 April 2010 - 02:27 PM
I was under the impression that any cutting to the roof made the car unroadworthy, properly done or not. Supposedly that's the reason why many hail-damaged cars are write-offs. If I don't need a roll cage, fine and dandy, but I'm thinking I will.
#23 StephenSLR
StephenSLR
  • 6,707 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 17 April 2010 - 02:40 PM
You can fix hail damaged cars and car sale companies sell them at discount without problems, it only damages the metal skin.
A write off is basically an insurance company classification, if it costs more to fix the car than what the car is worth they 'write it off' and pay you what you have the car insured for. Of course structural damage is considered to cost more to fix than what the car is worth.
Cars can be 'written off' by insurance companies yet still be structurally sound and roadworthy.
Lets say you insure a $500 bomb, someone comes along and 'keys' the car, it will cost more than $500 to respray the scratches - write off!
s
Edited by StephenSLR, 17 April 2010 - 02:43 PM.
#24 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 17 April 2010 - 07:39 PM
Yes I'm familiar with the concept of an "economic write-off", but I'd heard somewhere that no roof repairs were permitted for structual reasons. Evindently I was misinformed, so there's no problem - except getting some training in fabrication to repair the roof.
#25 dattoman
  • 16,473 posts
Posted 17 April 2010 - 09:23 PM
Don't go telling people with aftermarket sunroofs that !!!
No... you can repair anything...
Removing the windscreen on a modern car upsets the structure more than fitting a sunroof
Since the screen is a structural part of the car nowdays
