out the bonnet 6cyl ?
11 replies to this topic
#1 _T0rana_
_T0rana_
Posted 18 April 2006 - 11:52 AM
im going to be putting my airfilter out the bonnet on my 6cyl uc. and for street use i want it coverd by a scoop does anyone have any pictures of a scoop mounted on the side for a 6???
#2 _Chaotic_
_Chaotic_
Posted 18 April 2006 - 12:33 PM
Reverse scoop on my corolla, bonnets a bit rough its on the list of things to clean up.
Posted ImagePosted Image
#3 _CHOPPER_
_CHOPPER_
Posted 18 April 2006 - 06:26 PM
I saw an offset centre scoop on an HZ in the 80's. Looked pox. A super wide centrally mounted scoop would probably look batter, but also cost a lot more.
#4 _brett_32i_
_brett_32i_
Posted 18 April 2006 - 06:33 PM
i had 350 holley setup where i enclosed the filter and then fed it fresh air from 2 ducts under the front bumper (brake ducts) = pressurised air box.
worked well and no holes in bonnet
just another option...
#5 Heath
  • 18,320 posts
Posted 18 April 2006 - 06:34 PM
Have two bonnets, have two air filter elements, have two screws.
EDIT: Or Brett's suggestion
Edited by Heath, 18 April 2006 - 06:35 PM.
#6 _high_rpm_
_high_rpm_
Posted 18 April 2006 - 06:36 PM
or dont bother,lol
#7 _Pete_
_Pete_
Posted 18 April 2006 - 07:06 PM
On my old LC 4dr i used to run another bonnet with a small hornet scoop off to the side with a filter through it......mind you this was nearly 10yrs ago and i'm positive you won't get any real performance benefit from it, and the question of it will look any good is up to you. If you like it then go for it, if not another option like a Cold Air Induction set-up to the front of the car might be a better option.
An air filter through the bonnet always looks tough to me, but some bonnet scoops can be a little tacky looking, i'll try and dig out some old photos of my LC and scan them.
#8 _Herne_
_Herne_
Posted 18 April 2006 - 07:33 PM
I hope someone can prove me wrong here but I have always found off centre scoops and air filters popping through bonnets to be a tad off looking.
I have not seen many and this might just be because I have not looked hard enough or some people have similar thoughts to me and just don't like the look they give!
Perhaps I like things centered :)
Herne
#9 _brett_32i_
_brett_32i_
Posted 19 April 2006 - 07:03 PM
i sold one of my cam gears to a bloke with a 6-71 hanging off the side of an rb30 in an altered.
thing was tuff, ran either low 10 or 9 sec 1/4. but things in the centre look so much better....
#10 _torana_
_torana_
Posted 19 April 2006 - 09:34 PM
of to the side doesnt look right
#11 Heath
  • 18,320 posts
Posted 19 April 2006 - 09:52 PM
I disagree. Scoops can look okay offset, just not on Toranas.
Air filters and superchargers look sweet offset, just don't cover them with plastic or glass and it'll be right... just not legal.
#12 _CHOPPER_
_CHOPPER_
Posted 20 April 2006 - 07:02 PM
And I bet you think pimples look good too?
