Lexus 1uz-fe V8 in torana.
#26
_TOBES_
Posted 27 April 2006 - 06:37 AM
I put the photos on Cardomain last night so I could post them here. (BillsUC).
The black car is my son's 350 Chev powered UC. Wish I could have driven one of those to school when I was 17...
#27
Posted 27 April 2006 - 10:22 AM
I don't like the sump/front subframe though, I would have done a dry sump and lowered the engine before doing that to it. A lot of conversion guys I have spoken to won't comply that sort of a substantial mod to the front subframe in Qld.
Those chassis rails have obviously been trimmed back to fit it like that too.
Does it all fit under the bonnet? looks like it would.
M@
#28
_bango_
Posted 27 April 2006 - 05:48 PM
#29
Posted 27 April 2006 - 07:33 PM
#30
Posted 27 April 2006 - 08:04 PM
This is "conceptss"'s car that i was talking about and he is on here and is in Melbourne!!
Toranamat69 - can you you educate me more on a dry sump i know the basic idea but is it legal/engineerable in vic?????
As i have been quoted $1000.00 for a custom wet sump, any idea what a dry sump setup would be worth.
Dry sump is a better design anyway so if its not to much more it might be a better way to go????
Posted 27 April 2006 - 08:27 PM
Rails look chopped and x member is scary from a rego/engineers point of view.
#32
_tj81_
Posted 27 April 2006 - 10:20 PM
anyone wanna try changing the plugs in that thing ?
Edited by tj81, 27 April 2006 - 10:22 PM.
#33
_Chaotic_
Posted 27 April 2006 - 10:35 PM
#34
Posted 27 April 2006 - 10:53 PM
Correct, plugs are hidden under the black coversplugs are under the black toyota covers i'd say
#35
_tj81_
Posted 28 April 2006 - 10:39 PM
#36
_wombat_
Posted 28 April 2006 - 10:56 PM
#37
Posted 28 April 2006 - 11:02 PM
Not as powerful as the 1UZ, but they still hammer along.
RIM
#38
_wombat_
#39
Posted 29 April 2006 - 08:48 AM
Id prefer the twin turbo 2.5L then the 4.0L V8 anyday. The turbo destroys the V8 in the soarers all day long.My cousin has a spare Toyota Soarer (2.5L Straight 6 Twin Turbo) sitting in his shed, and a spare UC Sitting next to it. Soarer not going (hit a roo), UC not going too healthily. Hmm, 1JZ into Torana...
RIM
#40
_TOBES_
Posted 29 April 2006 - 08:56 AM
A 1UZ and a SBC side by side.
Those cams sure add to the height and width of the motor, although they are close to the same width at the exhaust ports. (The black cover on the 1UZ is not stock)
A 1UZ with the rear sump.
Still too far forward and clashing with the Xmember.
Front sump on the left, rear sump on the right.
Rear sump.
Side view.
I have the front sump version and will remove the pan and pickup and dummy it into position like that. I haven't looked for a rear sump as it may be easier to build from scratch than modify the existing one. The alloy sump is quite shallow at 68mm deep but overall height may still be an issue.
Might have a look at recessing the firewall a couple of inches as an easier alternative...
Ahhh, I love a challenge!!!
#41
_bango_
Posted 01 May 2006 - 08:36 AM
#42
_conceptss_
Posted 13 May 2006 - 01:52 PM
The booster is from a sunbird but is in the original mounting position. No dramas with clearance of the cam cover. A V8 booster will go in after modifying the raear of the cam cover and moving the booster mounting position as Toranamat did to his car. I contacted QUADCAM Aust. today. About $880 for a sump to suit a torana and the same price for headers. The sumps are made from 10mm Aluminium sheet for the pan rail and 3 mm sheet for the pan. The only drama I have with them as with the CRS (currently made from steel) sump is that they don't use the original lower bellhousing bolt holes which bolt the bellhousing to the sump. I've not done much to the hatch for a while.
Does any body have a complete UC front suspension/crossmember for sale in Melbourne?
LEXTEME .com PLANETSOARER, 1uzfe.com and v8supra.com have useful links and references. There's a bloke that advertises on ebay that has had stainless steel sumps made for 1uzfe's his user name is elliotaw.
#43
_CHOPPER_
Posted 13 May 2006 - 04:23 PM
What do you want, the bare crossmember or the whole lot? I can probably help.Does any body have a complete UC front suspension/crossmember for sale in Melbourne?
#44
_brett_32i_
Posted 13 May 2006 - 10:34 PM
out of the car, even has wheels/tyres.
#45
Posted 13 May 2006 - 10:38 PM
The V8 Soarers are also alot heavier. bigger stereo, more electrics, of course the V8. The come with a subwoofer standard.
RIM
#46
_SnotGobbler_
Posted 21 June 2008 - 11:42 AM
Anyone have pics etc?
Has these been done into an LJ torana yet??
_SnotGobbler_
Posted 24 June 2008 - 10:57 PM
surely someone out there must have latest info or new comments on a toyota 1uz into an lj torana. those things sound awesome n different
#48
Posted 25 June 2008 - 12:58 AM
#49
_conceptss_
Posted 25 June 2008 - 09:38 AM
CRS off the shelf sumps are crap (last time I checked them out) - last I saw they don't utilise all the original mounting holes or have recesses for the massive oil gallery return drains effectively restricting them by half. They don't utilise all the bellhousing mounting bolts (bottom two are missing) - The deep section of the sump sits too far forward and as the bottom of the block is below the bottom of the crank they may sit too low. Theres no baffling/scavenging and the lowest part of the sump hangs too low.
In all for the money you pay for a CRS and the extra work required to make them work correctly they are definaeately Not worth the money. Quadcams Australia Warwick Qld made a working pattern for a multi fit sump that you simply made your own deep section to suit. There's a guy in Frankston that uses a laser cutter in Carrum Downs vic to cut sump plates to which you weld ap a complete sump from - He made one for his escort from stainless - Steel or up to about 20mm Aly. can be cut. Thicker you go with laser and water cutting the less accurate the profile becomes - sort of like the way a jigsaw blade bends back with the pressure when cutting around shapes - results in an out of square cut.
As the sump on these engines is a stressed component the design and construction needs to be extremely strong and of high quality. The cad drawings for the sump plate aren't al that hard to get hold of ( the exhaust flange drawings are free on lextreme) Not all that difficult but a lot of time is needed to do it.
#50
_LHoon_
Posted 23 September 2008 - 09:33 PM
I am building up an LJ with twin turbo Lexus V8.
Check it out here --> TT Lexus V8 into LJ
