Trailing arms, which way??
Posted 19 April 2006 - 09:38 PM
i know the lower ones have the hollow side facing down. but is there a left and right one??
should the cap of the bush be pointing to the edge of the car or towards the middle.
again with the uppers.
thanks guys
feel really dumb posting this lol :(
Evan...
Posted 19 April 2006 - 10:55 PM
#3 _CHOPPER_
Posted 20 April 2006 - 07:04 PM
Posted 20 April 2006 - 07:06 PM
Posted 20 April 2006 - 07:33 PM
Posted 20 April 2006 - 10:54 PM
thaks gus !1
Posted 21 April 2006 - 07:32 AM
Come on RED you should know this.the holes are for the sway bay
The right upper arm has a small hole drilled where a self tappered bolt head screw goes in for the little rear brake line, rubber hose to affix.
Posted 21 April 2006 - 07:37 AM
Posted 21 April 2006 - 09:05 AM
The bottom ones are easy to tell coz you can see where the sway bar was attached, it's all clean and there are two holes in each.
I'll take your word for it though. Or I could get off my arse and look in the workshop manual but I'm not going to bother.
Posted 21 April 2006 - 01:01 PM
Apart from that, the upper arms are identical. It would be difficult to drill that hole with the upper arm in position though.
#11 _CHOPPER_
Posted 21 April 2006 - 06:24 PM
That's the one I was talking about. How could I have been talking about the sway bar mounts, when I clearly stated that ONE arm had the hole. Unless of course you want to believe the sway bar is only connected to one arm.Come on RED you should know this.the holes are for the sway bay
Posted 21 April 2006 - 06:55 PM
