Hi All,
I own a 4 dr LJ, 173, 3 spd Column auto and was wondering if someone could tell me what my car did look like as i bought it already sprayed & modded. Body ID Tag is as follows;
Model - LJ82569A
Body - 05338B
Trim - 1821 44R
Paint - 568 13134
Can i find out any more info from any of the other tags on my car??
I know its just a 4 dr but this would help me out guys!!
Cheers,
Mick
Decoding Tags
LOWS2
, Apr 20 2006 01:05 PM
6 replies to this topic
Posted 20 April 2006 - 01:05 PM
#2 _gm3300_
Posted 20 April 2006 - 02:20 PM
82569 Torana "SL" 4 door 6 cyl
Trim combination 1821 Glacier white/ 44R Medium Blue
Paint 568 13134 - Dulux Acrylic Laquer - Glacier White
grant
grant
#3 _JBM_
Posted 20 April 2006 - 03:32 PM
Trim 44 is Medium Blue and Black, what does the R refer to? Is it a special insert of some kind on the seats?
Your VIN, if the car was built after 10/72, will tell you the trim level, body type, original motor size, the year produced, which plant it came from and the series ie LJ. Your body no should make up part of the VIN. Your body no indicates it was built in Brisbane. Example VIN: 8C69DCH205338J.
The Body ID plate you got the trim and paint nos from may also have the Eng, Trans and Diff codes along the bottom.
1821 is Glacier White.
James
James
#4 _JBM_
Posted 20 April 2006 - 03:56 PM
I should have said:
Trim 44X is Medium Blue and 44Y is Medium Blue with a Black and White houndstooth seat insert, what does the R refer to?
The Body ID plate you got the trim and paint nos from may also have the Eng, Trans and Diff codes along the bottom if it is the newer type.
Also if you have an older VIN it would be like this: 82569JH205338.
James
James
Edited by JBM, 20 April 2006 - 03:59 PM.
#5 _gm3300_
Posted 20 April 2006 - 04:42 PM
Hi Mick, could you let us know what month of '72 the car was made?(i'm only guessing but comparing the body number to mine, i'd say April '72.) On early cars the last numbers on the vin did not match the body number.
Dr Terry might be able to help with the "R" reference in the trim code, but going by the parts book the 44R rear door trim is only variant listed for 82569 model, if there were other variations of trim there should be additional listings ie there's 40R, 40T, 40U for black trims under 82569, it's likely "SL" trim with no insert.
grant
grant
Posted 21 April 2006 - 08:55 AM
Thanks for the replies guys, the trim is still the original medium blue with walnut insert & black dash with walnut inserts (now removed but stored) & was originally glacier white. I got the folowing off the other tags on the car this morning -
Built - May 1972
VIN Plate - 82569JH233668
No. Stamped into Body - ALJ05329B
As you can see the Body No doesnt match the VIN as gm3300 said.
Thanks for your help guys, shame i dont have the Tags showing the driveline combo.
Built - May 1972
#7 _JBM_
Posted 22 April 2006 - 02:54 PM
I'll add Walnut insert to my list of Trim codes.
With the Body No not matching the VIN it makes it a bit harder to cross check things.
Good luck with sorting out your car.
James
James
