painting floor pan black ?
_A9XOSS_
Posted 28 May 2010 - 11:10 PM
type of look minus running gear. so should it be done in flat gmh black or a semi
gloss black. also what would be best, acrylic or 2pac.
_Ben_
Posted 29 May 2010 - 12:22 AM
someone will need to confirm as i have no idea
Posted 29 May 2010 - 12:50 AM
Edited by TerrA LX, 29 May 2010 - 12:52 AM.
_A9XOSS_
Posted 29 May 2010 - 09:45 PM
there was a lot of over spray from the factory colour, but not fully covered in it.
looks like gmh chassis black it is then.cheers.
_Quagmire_
Posted 02 June 2010 - 07:28 PM
Posted 02 June 2010 - 07:47 PM
_nial8r_
Posted 02 June 2010 - 08:25 PM
_Yella SLuR_
Posted 03 June 2010 - 08:04 PM
Edited by Yella SLuR, 03 June 2010 - 08:05 PM.
_DrFegg_
Posted 03 June 2010 - 08:06 PM
_gtr161s_
Its only good for guide coats !
You can get 2k made up as a semi gloss that looks great
_A9XOSS_
Posted 03 June 2010 - 09:19 PM
after consideration i'am going to go with the advise of the 2k black semi gloss, i also was thinking of going orange
underneath as with the top. but after seeing one done i personally did'nt go much on it, cheers.
Edited by A9XOSS, 03 June 2010 - 09:21 PM.
_A9XOSS_
Posted 04 June 2010 - 08:59 PM
_A9XOSS_
Posted 07 June 2010 - 10:57 PM
will post pics once all done.
_nial8r_
Posted 08 June 2010 - 06:35 PM
They actually aren't painted underneath from factory, unless you call a mixture of GMH-black and overspray painted!!! I just did mine like this:
sh*t thats just what mine looks like until tomorrow,,, and whats with the left rail on these things ?? mine was the very same too i guess everyone used it to jack the car up at some point, but why not the right side
_stu.slr_
Posted 08 June 2010 - 07:09 PM
Posted 03 April 2013 - 04:39 PM
I did the floor with Acrylic Midnight Black with a flatening base on the A9X, it came up perfect. Did a friends in 2K and found the more coats I sprayed the glossier it got, it also had a flatening base as well, the Acrylic looked heaps better.
Posted 03 April 2013 - 08:15 PM
Hi #1 A9XOSS
I would recomend doing the underside in 2k , if you buy normal gloss 2k you add a flattening base ( 60% black 40% flattening base )and can adjust the amount of gloss you require
cheers nomaro33
This thread is nearly 3 years old. It's probably long since painted.
_Quagmire_
Posted 04 April 2013 - 02:26 AM
_ohhgeee_
Posted 19 August 2013 - 09:55 AM
i know its an old thread and all but im upto this part on my build atm and was wondering how you guys cleaned the underbody in the first place??
i dont have a rottiserie and the cars not in a rolling state so cant send it off to get blasted in anyway but im keen and just want a neat look.
i do have the car jacked up pretty high though so there is room to work.
there that bitumen looking crap, alot of grease, grime, the odd paint and afew other things that god will only know.
how do i get it off??????
ive tried scraping, degreasing, girnie and alot of elbow grease but im not getting anywhere..
please help
someone suggested hiring a high pressure steam cleaner is this an option?
#21
Posted 19 August 2013 - 10:02 AM
You will find a paint scraper will remove most of the build up, it's upto you from there to get on your back for the hard part.
#22
Posted 19 August 2013 - 10:06 AM
I started with degreasing, high pressure is better. Then using an old sharp wood chisel scraping as much off as you can, then I sand blasted at home but others use the wire wheel to finish.
Marty
#23
_ohhgeee_
Posted 19 August 2013 - 10:12 AM
even after alot of scraping theres still a layer of grease or grime that i cant fully get off enough to paint over though..
#24
Posted 19 August 2013 - 01:28 PM
#25
_Quagmire_
Posted 19 August 2013 - 01:52 PM
but sand blasting or a steam pressure cleaner works quicker...messier but quicker lol
when i did it for a living that's all we used
Edited by Quagmire, 19 August 2013 - 01:53 PM.
