so I wanted to put a few pics up I have paint on my UC now .
I have just started to rub it back, its got a bit more rubbing needed before the buff but is starting to look like a car again so I am happy, anyway the glass and lights will go back in next week and hopefully I can have on the road in a month we will see
cheers antony
ps. anyone know if an early 80's falcon ute lsd diff head will fit in a sunbird diff housing? I have had a few guys over here tell me it will. anyone know
https://cache.gmh-to...UC/IMG_1693.jpg
https://cache.gmh-to...erlowUC/car.jpg
update on my UC
_superlowuc_
, Apr 22 2006 12:38 PM
8 replies to this topic
#1 _superlowuc_
Posted 22 April 2006 - 12:38 PM
#2 _efi-202_
Posted 22 April 2006 - 01:17 PM
looking good.. lovely colour
#3 _UCV80_
Posted 24 April 2006 - 08:43 PM
Its lookin hot man good work.
Body looks sweet as
what donk is he or she getting? a 186?
,Nathan
Body looks sweet as
,Nathan
#4 _superlowuc_
Posted 25 April 2006 - 08:01 AM
I was planing on putting the worked 186 I have but I changed my mind and now i am putting in a rebuilt blue 3.3 out of a commy. The blue motor just seemed a better building block for me, as it already has stronger interals and a 12 port headed.
still working out the gear box situation. I have a M20 and a commy 5 speed for it will most likey use the M 20
the motor will get a 4 barrel secondary vac holley 390, s/b chev fuel pump, msd coil and leads , elec dizzy , extractors, and a few other bits.
hopefully a hot cam if the one from my 186 will work
anyway thanks for the intrest
antony
antony
Posted 25 April 2006 - 11:03 AM
I can't see why the 186 hot cam won't work in the blue motor. All sixes are the same as far as that's concerned I think.
Whereabouts are you located? And what extractors will you be running. Will you convert some 9-port extractors to suit the 12-port head or have some others in mind?
....or maybe Commodore extractors work, but I doubt it.
#6 _superlowuc_
Posted 25 April 2006 - 12:22 PM
hey I am looking at trying to covert an old set of 9 ports i have if it does not work I will try to use the dual branch cast manifold that are on the motor ( out of the commy)
I live in New Zealand bro
I was told that a factory 186 cam ( built up and reground) may not work with out having the tail shaft reground I donot know if its true or not but i have not had time to find out yet, anyone know?
I have photos of the cam on an other post ( max rpm for blue motor )
cheers antony
cheers antony
#7 _UCV80_
Posted 25 April 2006 - 12:39 PM
Nice.. The blue engine will be great. I recon theres a bit more torque behind them with there fully counterweighted crank. and the stronger internals are great, No cardboard timing gears
A nice big cam would be sweet
commo extractors fit, i used them on my previous engine which was a 12port blue. shouldnt be too hard to convert some 9ports, just need a grinder
I put a 12port standard manifold (varajet) on my red engine and it clashed with the red extractors majorly! so much granding haha, u wont have any probs with a 4barell manifold though!
good luck!
,Nathan
good luck!
,Nathan
#8 _superlowuc_
Posted 25 April 2006 - 01:00 PM
nathan got any pics on mounting that commy radaitor I am using one in mine as well and any interested to see how you mounted it
cheers antony
cheers antony
#9 _UCV80_
Posted 25 April 2006 - 01:42 PM
Here is a pic, got 2 mounts from bunnings
this is an old pic, i bolted them in more firm now
Loki on the forums put one in his slr, he used the original commodore mounts, looks like it worked very well. probly a better idea.
,nathan
,nathan
