carby on a 304
29 replies to this topic
#26 _UFO304_
_UFO304_
Posted 25 November 2013 - 10:06 AM
You can run the Manual pump.
It isn't actually a lobe, its what they call the fuel pump eccentric.
Its a bolt on metal ring that bolts onto the main bolt of the cam when you bolt the timing gear on.
The really late holden v8's also don't have the cut out in the timing cover, so you would have to cut it out, or replace it with an older style timing cover.
#27 _UFO304_
_UFO304_
Posted 25 November 2013 - 10:13 AM
Fuel Pump Eccentric.
Only comes on models with a Mechanical pump.
#28 _bangbang_
_bangbang_
Posted 25 November 2013 - 12:37 PM
Thanks heaps for the help!! Might be easier to put an electric pump on there I think.. The engine is fully installed into the car now. I'm running a 650dp carby, do you know if a standard electric pump would keep enough pressure up to that carby by any chance? Thanks again :)
#29 _Mint_
_Mint_
Posted 25 November 2013 - 06:51 PM
under wot no it probably wouldnt the stock pump runs at about 4 psi the high pressure(or l34) 7 psi which is what i have on my 304 with 6fiddy dp Holley..Goss still make them and also kits which has a heavy sprung diaphram and hi flow valves..
Edited by Mint Julip, 25 November 2013 - 06:52 PM.
#30 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 05 September 2014 - 02:50 PM
question.. Would a standard vs 304 with tri y pacemakers (manual) make more power with a harrop/torque pwr manifold & holley/speed demon carby?
Been searching online. but all the links lead to 355 strokers
