PWR RADIATOR PROBLEMS
#26
_Yella SLuR_
Posted 13 July 2010 - 09:31 PM
First one was rough and knocked around a bit, so I sent it back. Latest one is impecable. Little concerned about the position of the lower mounting hole, but top looks in the right position, might need a bit of attention from Mr. Drill.
#27
Posted 13 July 2010 - 09:34 PM
I can't say a bad word about it
#28
_1uzbt1_
Posted 14 July 2010 - 10:45 AM
yes,and tap water,instead of distilled,plus i had .3 of a volt stray current in the radiator.
Whoa, thats real high, no wonder it died.
Interesting enough ive found mixed coolants will give the same readings.
#29
Posted 14 July 2010 - 06:27 PM
When i did i got about 1.4V by sticking a probe into the water (while hot) and the other to earth... Wonder if i did it right?
Oh.. and i run 90%+ straight GMH green concentrate.
#30
Posted 14 July 2010 - 06:55 PM
KOOL-IT� Electrolysis Indicator
KOOL-IT� Electrolysis Indicator Instructions
#31
Posted 14 July 2010 - 07:07 PM
Thanks for that!
I suppose you could do the same with a multimeter?
#32
Posted 14 July 2010 - 09:01 PM
The KOOL-IT device is just a simplified dedicated device which unfortunately cost more than a cheap multimeter.
Edited by ls2lxhatch, 14 July 2010 - 09:04 PM.
#33
_1uzbt1_
Posted 15 July 2010 - 10:55 AM
#34
_Road Runner_
Posted 15 July 2010 - 12:18 PM
#35
_1uzbt1_
Posted 15 July 2010 - 02:44 PM
BTW
Why cant i edit???
#36
_Eedman_
Posted 15 July 2010 - 03:33 PM
The Kool-IT device seams to have quite a high "acceptable level" when it measures stray current.Idealy you dont wont any but i know(and use) Nissan's 0.05 volts at a maximum on aluminium.Some even think 0.02 is the maximum.
BTW
Why cant i edit???
you can only edit within a certain timeframe, once you have left the post a little while, that function dissapears.
#37
Posted 15 July 2010 - 06:19 PM
Just out of curiosity, why analogue?
#38
_1uzbt1_
Posted 15 July 2010 - 06:28 PM
i just want to add to previous post instead instead of posting again.
#39
Posted 15 July 2010 - 06:46 PM
I thought that maybe the analogue was more accurate at those tiny voltages.
Cheers! And thanks!
#40
Posted 15 July 2010 - 07:00 PM
#41
Posted 15 July 2010 - 07:22 PM
Just a thought!
#42
_Brad1979UC_
Posted 15 July 2010 - 08:03 PM
#43
Posted 16 July 2010 - 08:28 PM
Cheers!
