red 6 with davis craig elec water pump
_kdsa_
Posted 28 June 2010 - 06:45 PM
Posted 28 June 2010 - 07:15 PM
_Drag lc_
Posted 28 June 2010 - 07:47 PM
anyway how did it go on the dyno mate?
Edited by Drag lc, 28 June 2010 - 07:48 PM.
_kdsa_
Posted 28 June 2010 - 08:09 PM
Posted 28 June 2010 - 09:02 PM
it works good if your stretched for space between the motor and radiator
_BlownUC202_
Posted 28 June 2010 - 09:39 PM
Posted 28 June 2010 - 10:21 PM
Getting a water pump that actually supplies decent pressure and doesn't cavitate should be a priority. That may be able to be achieved with an electric one, I imagine it would be possible for that to do a good job but it isn't the only option (I've never worked with them but I am aware that they are becoming increasingly popular with the V8 guys). Mechanically driven water pumps can be hotted up with improved impellers and have housing modifications to improve their performance in the same way that you can port a head. You don't hear about it much because not many people do it.
Depending on what the car is doing, the radiator, fan setup, thermostat etc can also be pretty important.
_kdsa_
Posted 29 June 2010 - 10:31 AM
_torbirdie_
Posted 29 June 2010 - 02:19 PM
[Thanks guys for your imput very helpful and just the info i was after, my block has been grout filled and there is little room umder the impellers now, so i think the ewp is the way to go,cheers ken
Are ewp's being fitted as standard equipment on newer cars? might be the answer to if they really work or are good value for money.
_Drag lc_
Posted 29 June 2010 - 06:43 PM
How much grout has the block got in it?.
i have a n/a 202ci with grout level with the bottom of water pump spigot in front of block to the bottom of the rear welsh plug and it has done a fair few klms (and one strip meeting hehe) now with no noticable diffrence in engine temp ,to no grout.
Cheers Hayden
_kdsa_
Posted 29 June 2010 - 07:47 PM
so are you running the orig water pump on the motor and what about the one your building, spoke to eze 10s performance yesterday he said they grout fill all there blocks and they all run an ewp, so i figured i go that path, also spoke with pwr today anew radiator for mine with 13 inch fan 1150, there pricey.
so mate what turbo you got on that thing anyway, what power are you going for.
_coupe202_
Posted 29 June 2010 - 09:54 PM
_kdsa_
Posted 29 June 2010 - 10:10 PM
_2wild4u_
Posted 29 June 2010 - 10:54 PM
Posted 29 June 2010 - 11:51 PM
Running a motor too cool will frOck it very promptly.
_2wild4u_
Posted 30 June 2010 - 12:10 AM
_Drag lc_
Posted 30 June 2010 - 05:38 PM
yeah mate it has got genuine holden water pump on it it hasnt got alot of comp but it has ova 11to 1.
yeah runnas engine will have the genuine water pump fitted aswell as we have modified the water flow in the head to help prevent detonation as im sure u are well aware of, if yours has a iron head on it.
Yeah it has a GT42R on it , hp well runna202 (who actually ownes the engine) maybeable to give u a more informed answer as i carnt be certain. but a far amount im guessing.
any pics of yours Ken?
Cheers Hayden
_kdsa_
Posted 30 June 2010 - 06:59 PM
_Drag lc_
Posted 30 June 2010 - 07:46 PM
Posted 30 June 2010 - 08:02 PM
yes thermostat is fine, nothing else was changed apart from the water pump setup, thats why i will put the controller on it now so it can regulate voltage to the pump
I doubt that the electric water pump would be responsible for the engine running at 40-50 degrees. I just do not see how it is possible without the water going through the radiator.
I personally would not vary the speed of the electric water pump. In my opinion the faster the water flows around the block the better regardless of the temperature. The last thing you want is hot spots in the heads when the block has not reached operating temperature.
#21
_kdsa_
Posted 30 June 2010 - 08:40 PM
_@milco@_
Posted 30 June 2010 - 11:12 PM
altho flowing to fast can be a problem as well, because it will not have time to "absorb" the heat form the various parts of the engine/metal/cast..,..
#23
Posted 30 June 2010 - 11:18 PM
It turns out that the faster water flows the more turbulence is produced and the better the heat transfer is. The Stewart Components tech tips are definitely worth a read.
Stewart Components Tech Tip #5
Coolant must flow through a radiator tube at a velocity adequate to create turbulence. The turbulence allows the water in the center of the tube to be forced against the outside of the tube, which allows for better thermal transfer between the coolant and the tube surface. The older radiators benefited from baffling inside the tanks and forcing the coolant through a serpentine configuration. This increased velocity and thus the required turbulence was restored.
Stewart Components Tech Tip #3
A common misconception is that if coolant flows too quickly through the system, that it will not have time to cool properly. However the cooling system is a closed loop, so if you are keeping the coolant in the radiator longer to allow it to cool, you are also allowing it to stay in the engine longer, which increases coolant temperatures. Coolant in the engine will actually boil away from critical heat areas within the cooling system if not forced through the cooling system at a sufficiently high velocity. This situation is a common cause of so-called "hot spots", which can lead to failures.
#24
_2wild4u_
Posted 30 June 2010 - 11:26 PM
the water is still going through the radiator, i think the problem is the water is being pushed around too fast, i even checked the temperature of the block, heads etc with a laser temp reader, car never went over 90 degrees before electric pump was fitted, which is why i didnt want to experiment with the electric pump.
#25
Posted 30 June 2010 - 11:29 PM
