red 6 with davis craig elec water pump
#26
_2wild4u_
Posted 30 June 2010 - 11:48 PM
#27
Posted 01 July 2010 - 12:27 AM
The factory thermostat bypass is via the heater back to the water pump. You could add a line from the intake manifold to the timing cover as a bypass and run a normal thermostat.
Another option is the John Bennet De Tomaso Pantera remote thermostat and bypass. The thermostat is moved to the middle of the top hose with a 5/8 hose (from memory) that connects to a mixing block in the middle of the bottom hose. When the thermostat is closed the water circulates via the bypass. When the thermostat is open water circulates through the bypass and the radiator. I saw a similar setup at Choice Radiators in Bellevue in the early 90's.
Edited by ls2lxhatch, 01 July 2010 - 12:29 AM.
#28
_Drag lc_
Posted 01 July 2010 - 06:16 AM
correct me if im wrong but i saw this car on ebay a few days/weeks ago for sale?.
Cheers Hayden
#29
_kdsa_
Posted 01 July 2010 - 02:36 PM
correct mate sold the ute but have decided to keep the motor spent to much time and money on it.
#30
Posted 01 July 2010 - 05:17 PM
The thermostat relocation kit is not currently available unless someone else is reproducing it.Another option is the John Bennet De Tomaso Pantera remote thermostat and bypass.
#31
Posted 01 July 2010 - 07:08 PM
Choice Radiators
22 Wells St
BELLEVUE
WA 6056
08) 9250 3232
Alternatively you could probably modify two Meziere inline thermostat housings to do the job. They are available in 1.25" and 1.5".
#32
_kdsa_
Posted 01 July 2010 - 07:31 PM
#33
Posted 01 July 2010 - 07:51 PM
If the higher engine temps are caused by lack of coolant flow at idle then the EWP will help.
If the high temps at idle are caused by lack of airflow through the radiator then the EWP will not help.
#34
_kdsa_
Posted 01 July 2010 - 08:00 PM
#35
Posted 02 July 2010 - 01:00 AM
Hey Ken,
Cheers Hayden
yeah i saw that too, nice looking hr ute!
what model sedan is the motor going into??
#36
_kdsa_
Posted 02 July 2010 - 05:46 PM
Posted 02 July 2010 - 11:27 PM
#38
_kdsa_
Posted 04 July 2010 - 12:08 PM
#39
Posted 06 July 2010 - 12:17 AM
i think theres a few of the sedan in there too. havent touched the sedan in a few years. it will be started round november
