Edited by ilovea9x, 02 July 2010 - 02:11 AM.
Gearbox crossmember
ilovea9x
, Jul 02 2010 02:10 AM
3 replies to this topic
Posted 02 July 2010 - 02:10 AM
I have modified the gearbox crossmember in my torana to fit up to a celica gearbox and even after measuring it atleast six times before I drilled the first hole the gearbox sit to one side, the mount is in the dead centre so is the chassis off to one side or is the tunnel not in the centre of the chassis on my car.
Posted 02 July 2010 - 06:41 AM
The engine and tunnel probably aren't in the centre
#3 _nial8r_
Posted 02 July 2010 - 08:00 AM
or the holes on the G-Box are not in the centre, best to line the box up 1st with it bolted to the engine then take your measurments
Posted 03 July 2010 - 11:04 AM
I found another crossmember and measured the factory slots they seam to be 3 mm off to one side, I can fix this with the mount will just slot the holes and move the box over.
