New Parts Hauler - WB 1 Tonner
Posted 06 July 2010 - 10:27 PM
I might have paid a bit much, but it had most of the gear I wanted, 308, turbo 400, dual fuel, power steer, aluminium tray, hardly any rust etc
Plans are to tidy it up a bit, replace the LH guard, tidy the interior and have fun driving it.
The motor is a reco unit with about 45,000 km's on it, I might put this into my LX project, judging by the inlet manifold its about the right engine for an LX - anyone want to confirm this ?
It drives well but chews through the gas, I'll try to do an accurate test and then start trying to improve the economy.
Posted 07 July 2010 - 12:14 AM
Nice pick up, sounds like it has some good gear and the price is right. But I'd seriously consider putting a 253 in there and sorting out a better gas system. The carb is probably stuffed from supporting that gas elbow and it will all be out of tune etc. If you turn that 300A upside down and sit in straight ontop of a four barrel throttle-body would cost next to nothing and probably do wonders if it was tuned right.
Posted 07 July 2010 - 05:51 AM
He's moved to the dark side.
Posted 21 August 2010 - 12:17 AM
I'll put some plugs and a new air filter on it and get the gas mixture set proerly.
Then I've got some 15 inch Caprice alloys, I'll fit some used 15" 4wd tyres to see if higher gearing makes a difference.
Posted 21 August 2010 - 12:25 AM
what is the engine no. prefix?
Posted 21 August 2010 - 11:03 AM
Posted 21 August 2010 - 11:13 AM
#8 _Quagmire_
Posted 21 August 2010 - 11:19 AM
got to keep the mantiance up on it at all times else you start having problems
i got a points system here if you want to convert backwards
but then a new coil should only be about the same as postage etc
Edited by Quagmire, 21 August 2010 - 11:21 AM.
Posted 21 August 2010 - 11:23 AM
and
secondary between terminal - (1) and HT coil lead connection (4) = 5 - 7 Kilohms to gain the best performance, less, especially on the primary will lead to a weak spark that you will never tune out.
AFIK there are only two coils available from Bosch that suit HEI, the BEC 715 and BEC 716, both are black.
Posted 22 August 2010 - 11:07 PM
#11 _Woodsy_
Posted 23 August 2010 - 07:51 AM
Posted 23 August 2010 - 03:49 PM
Posted 12 January 2011 - 10:49 PM
Pics and fuel figures to follow.
#14 _CHOPPER_
Posted 13 January 2011 - 08:38 PM
Posted 13 January 2011 - 09:32 PM
I did a fuel economy check and its down to 22 L/100 km which is great compared to what itt was, thats without touching the engine, so maybe with a tuneup even better things are possible.
Posted 19 February 2011 - 10:37 PM
http://cgi.ebay.com....=item3cb532b138
Edited by micklx, 19 February 2011 - 10:44 PM.
Posted 20 February 2011 - 07:31 AM
