HQ Diff Hop question
Posted 25 April 2006 - 08:45 PM
I took the monaro out for a squirt today and gave it a bit of a hammering.
Appart from my oil pressure problem, Ive found something odd happening with my Diff.
Since ive changed to the mini-spooled 3.7 centre ive noticed that when i try and lay a skid, that the diff hops like it was a leaf sprung car axle tramping.
The question is, Ive never had this problem with the 3.25 LSD diff centre and i didnt feel it in the early days of the 3.7 Spooled centre.
I'm just running normal 28 spline axles ( one tonner ive been told?? I dont know??) so i'm a bit concerned.
I gave it a squirt today and near rattled me fillings out.. VERY violent and the marks on teh road were as if it was a doorslammer tyre shaking!
Anyone have any ideas? The Tyres/wheels havent changed so i dont *THINK* balance is an issue...
Cheers!
#2 _CHOPPER_
Posted 25 April 2006 - 09:06 PM
Posted 25 April 2006 - 09:09 PM
My VZ clubby axle hops just as bad as I remember my torana doing it.
Do you have another set of shocks that you could try?
Maybe yours chose this day to pack it in.
Posted 25 April 2006 - 09:11 PM
Posted 25 April 2006 - 09:15 PM
Make sure you ask for Ralph!
Posted 25 April 2006 - 09:24 PM
All my suspension compenets have had about 12 months of road use... ( are slightly older but yeah.. sitting around!).
They are Koni adjustable shocks so maybe i can stiffen them up a little?
Thanks for the quick replies!
#7 _CHOPPER_
Posted 25 April 2006 - 09:32 PM
#8 _Oldn64_
Posted 19 May 2006 - 02:48 PM
Check that all your bushes are in good nick. these are what keeps the diff in its right place. so if these are warn they will have a huge reaction to the diff placement. I would suggests that if you do look at replacing the rear bushes with nolathane that only the BOTTOM bushes get replaced with plastic, leave teh top rubber, the ride will be kinder. If not you will potentially solve the axle tramp but reduce the tractablity of teh vehicle (which I am sure you do want as skids all over the place is not fun.....)
Posted 19 May 2006 - 03:32 PM
I'm going to double check everything under there.. it's gotto be something that's happened since the diff change cause it simply didnt happen with the LSD and also in the early times with the 3.7s.. I'll be checking the bushes and also mounting points apprently that's a major problem area!
Anyway.. I'll let you all know as i get time to sus it!
#10 _CHOPPER_
Posted 19 May 2006 - 10:20 PM
Posted 19 May 2006 - 10:27 PM
#12 _LX406_
Posted 21 May 2006 - 06:57 PM
Posted 22 May 2006 - 01:19 PM
Do you have any pics/info on the McDonald Bros arms? I had some other brand ( wont say what company) adjustable upper arms in the car and they were pathetic! they twisted and all sorts of nasty stuff!
Thanks for the tip!
Cheers!
#14 _ChiaLX_
Posted 22 May 2006 - 01:39 PM
http://www.mcdonaldb...lowertrail.html
This is for the upper adjustable arms.
http://www.mcdonaldb.../upperarms.html
Mick
Edited by ChiaLX, 22 May 2006 - 01:42 PM.
Posted 22 May 2006 - 01:52 PM
They look to be a bit better than the ones i used previously. I'll see how my gear looks and wether teh arms are causing the problem and see how it pans out from there!
Posted 22 May 2006 - 05:00 PM
#17 _CHOPPER_
Posted 22 May 2006 - 06:51 PM
#18 _LJ355_
Posted 29 May 2006 - 08:21 PM
Posted 30 May 2006 - 06:33 PM
#20 _Lostit_
Posted 10 June 2006 - 09:34 AM
#21
Posted 10 June 2006 - 08:45 PM
No mate it doesnt happen when accelerating ( even hard acceleration) or at any speeds at all!
It ONLY occurs when you loose traction! That's the weirdest thing! I cant pin it down to anything but the diff moving around because of this...
Unis, tailshaft balance even a bent axle would all show up during normal driving and not ONLY under lost traction situation!
Anyway i'm FINALLY getting the car engineered.. waiting for the engineer to ring me and THEN i'll be fixing this problem!
Cheers!
#22 _jabba_
Posted 14 June 2006 - 10:28 PM
#23 _Oldn64_
Posted 15 June 2006 - 03:49 PM
PS: The only other thign I have thought of tiny is knowling that your car has been played with are you sure the pinion angle was setup correctly?
#24
Posted 18 June 2006 - 02:45 PM
I've got koni adjustables all round in the monaro anyhow, so i don *THINK* it shoudl be the shocks.
It really only started to do it after a few good blasts witht he 3.7 ratio and after the skid pan day's hammering etc.
I'll be trying to get under it as soon as i can to sus it out, but work's been SO BUSY at the moment that the car has had to take a back seat for a while!
Anyhow, I'll definitely let you know how it goes!
Tiny.
#25
Posted 19 June 2006 - 05:31 PM
Edited by makka, 19 June 2006 - 05:31 PM.
