Hi all,
Am still on the quest to put a 5 speed behind the 253 in the LX torana,
Thought I had the second last set of pieces,
but I was wrong,
Got a flywheel and pressure plate,
but it appears that the one I got is too small,
The clutch plate that came with the CRS kit measures 254mm or 10 inches across,
the marks on the pressure plate measure 240mm or 9.5 inches.
From inside of the tab marks on the flywheel
where the pressure plates mounts is 275mm.
Do I get a bigger pressure plate?
Is there a bigger pressure plate?
Do I need another flywheel as well as pressure plate?
Or swap the clutch plate for a smaller one?
but I think bigger the better for the clutch plate.
Any ideas,
Chris
Holden 253 FlyWheel and Pressure plate Types
_big chris_
, Apr 26 2006 05:22 PM
8 replies to this topic
#1 _big chris_
Posted 26 April 2006 - 05:22 PM
#2 _lx5008_
Posted 26 April 2006 - 05:26 PM
holden 308 had a 10" pressure and clutch plate and 253 are smaller.
#3 _big chris_
Posted 26 April 2006 - 06:24 PM
Hey LX 5008,
Is the same flywheel used for the 308 and 253?
Chris.
Chris.
#4 _lx5008_
Posted 26 April 2006 - 07:23 PM
yes
#5 _big chris_
Posted 26 April 2006 - 07:59 PM
Ok,
So I need a 10 inch 308 pressure plate to bolt to my flywheel,
and I can use the 10 clutch for my supra gearbox?
Chris.
Chris.
#6 _lx5008_
Posted 26 April 2006 - 08:27 PM
that will work
#7 _big chris_
Posted 03 May 2006 - 05:41 PM
Hey,
have been looking for a 308 pressure plate,
have come across a few on ebay selling a 10.5 inch pressure plate.
Would that fit the standard Holden red V8 flywheel?
Or is that a commodore blue motor type?
Chris.
10.5 inch Holden Clutch.
http://cgi.ebay.com....1QQcmdZViewItem
10.5 inch Toyota Clutch, which I already have a Supra Clutch,
Chris.
#8 _MRNOS_
Posted 03 May 2006 - 09:30 PM
Where in brissy are you im on the southside, im pretty sure i have a 10.5inch pressure plate here i'll measure it in the morning give me a call if you're still looking for it 0433225372
#9 _big chris_
Posted 04 May 2006 - 12:07 PM
Hi NOSLH,
you have a PM, will call you tonight.
Chris.
Chris.
