Manifold for 308
10 replies to this topic
#1 boblhslr
boblhslr
  • 199 posts
Posted 01 August 2010 - 11:45 PM
Hi guys,
I have a 308 with a performer intake. I am looking to go for a single plane manifold. I am useing the car mainly as a drag car with the ocasional street duties. The engine has red heads l34 spec, 650dp holley, roller rockers, crane 5649 cam (rpm 3000- 6000), It is stock stroke with flat tops and it has high comp.
I was wondering what poeples thoughts are on changeing the dual plane to a single and which one would worker better with my set up. I was thinkingof useing a redline torquer low rise or a redline high rise. what are poeples thoughts on which manifold to use.
#2 dattoman
Posted 02 August 2010 - 12:31 AM
If its manual.... go for it
If its auto.... you might not like it as much for street duties
#3 TerrA LX
Posted 02 August 2010 - 02:23 PM
Yeah it would really depend on what box/stall, diff ratio, tyre size etc.
Does it redline across the lime ATM?
WHAT TIMES ARE YOU PULLING NOW????? :)
IMO a switch to a 750 on the strip would prolly pull a few more ponys up top.
have a look at thius members car it runs mid 12's, maybe PM him if he does not see this thread.
#4 _jima9x_
_jima9x_
Posted 02 August 2010 - 04:55 PM
Either try an Edelbrock torker or as I did a torque power dual plane - not cheap but definately delivers. Jim
#5 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 02 August 2010 - 08:28 PM
I have personally not used either of the Torque Power intakes but I swear by the Performer as opposed to the Torker.
I ran good 11's years ago with a Performer and 2" divided spacer and I have seen cars in the tens with Performers. The Torker needs a lot of work and a lot of RPM to really work.
I recently saw a 355 with HQ heads lose the Performer and fit a TP single plane and gain a little everywhere (10Kw peak on a 220Kw engine)IMO it wasn't worth the investment or the hole in the bonnet.
JMHO
#6 TerrA LX
Posted 02 August 2010 - 10:25 PM
I have only ever used the performer or a OEM manifold, no complaints here.
#7 _Brad1979UC_
_Brad1979UC_
Posted 02 August 2010 - 10:48 PM
I'm running what sounds like a similar specd motor to yours exept its stroked and on bbq fuel.
I think that's interesting about the differences with the performer and redline torker.
I'm running a torker single plane and reckon its grouse however its been on the motor the whole time, I don't really have a comparison. If going for that though if you can id agree to run maybe a 750 with a spacer 1/2 to 1" on top.
#8 boblhslr
boblhslr
  • 199 posts
Posted 04 August 2010 - 05:56 PM
Hi guys, I was mainly looking at the redline torker manifold as it has a raised floor. But was wondering if the high rise one was better then the low rise torker.
My car atm is running 13.05@106mph But I have a crap 60ft time with a best of 2.00. This is due to the converter being a 3000rpm and running through a turbo400. I am changeing to 3800rpm converter and a turbo 350 to help the 60ft times. But was also looking for maybe a gain in hp by changeing the intake to a single plane. The car has a 9" with 4.11 gears and 26" slicks. But not turning the tyers off the start.
#9 _azureblueslr_
_azureblueslr_
Posted 04 August 2010 - 06:14 PM
hi bob
dont change the manifold yet
fitt the bigger stall and see how she runs first ,also check/modify the carb and ignition system to make sure they are working 100% with your engine combo
if anything your 60 ft will be worse with the torker not better
#10 _SS Hatchback_
_SS Hatchback_
Posted 04 August 2010 - 10:09 PM
I cant compare the 2 manifolds as when i had the performer it was on a totally different engine but now the redline torker on this engine works fine. Im running a 3200 stall and 4:11 rear ratio and i have plenty down low. My 60ft times are just under the 1.9 but thats mainly due to the fact i cant get traction and ran a [email protected]. I get under 1.9 when i leave at half throttle and not stalled up if i nail it im up around the 2.1. So i cant compare the the mainfolds but im extremely happy with the redline one.
#11 TerrA LX
Posted 04 August 2010 - 10:40 PM
:burnout:
