Hi all, I have just got my hands on a big nut master and I want to fit it to my LC. Problem is the LC is running a disc front and it has drum stamped on the big nut. please can anyone tell me if I can still run this master cylinder with my disc setup, if not is there any way of modifiying it to suit?
Many thanks.....Adam
Disc/Drum Big Nut Master Cylinder
_LCGTRRRR_
, Apr 28 2006 12:48 PM
2 replies to this topic
#1 _LCGTRRRR_
Posted 28 April 2006 - 12:48 PM
Posted 28 April 2006 - 04:26 PM
Hi Adam.
Yes, it can be made to fit. The only difference between the 4 wheel drum type & the disc/drum type (apart from the stamping) is the extra residual pressure valve. 4 wheel drum cars have two, one in each of the outlet fittings & the disc/drum type has only one (for the outlet to the rear drum brakes).
The other thing too, is that if you're fitting this for originality, there are 2 types. The early LC (before 7/71) has the HK/HT/HG style with rounded ends. 7/71 onwards have the HQ/HJ style where the body casting has more squared-off ends.
Dr Terry.
Dr Terry.
#3 _LCGTRRRR_
Posted 01 May 2006 - 02:24 PM
Thanks Dr Terry, very helpful. So to make it fit its just a matter of removing the residual pressure valve from the front outlet?? My LC is early '70 and the big nut came off a HK so it will be good for originality.......
