Intake gaskets
35 replies to this topic
#26 _lostinspace_
_lostinspace_
Posted 26 August 2010 - 10:16 PM
Thanks Terry
I will give it a go hopefully this weekend.
Thanks to all for your help.
#27 TerrA LX
Posted 26 August 2010 - 10:38 PM
You are welcome to borrow my holdens manuals if you wish maybe out your way tomorrow evening.
#28 _lostinspace_
_lostinspace_
Posted 27 August 2010 - 12:16 AM
That would be great I need to know what the torque and the sequence of the bolts are.
#29 _Yella SLuR_
_Yella SLuR_
Posted 27 August 2010 - 03:25 PM
Yella broke out of the shed this morning with the new manifold in place, and no smoke!!!
In the order of the gaskets, I'd do ones up the sides first, then do the front and back. Just seemed to work out better when I did it that way. I also cut up some 8mm steel bar and made some dowels. Worked a treat.
25-30 lb/ft of torque. Pretend the carbie holes in the middle are the centre and work out in an ever increasing circle.
#30 TerrA LX
Posted 27 August 2010 - 07:23 PM
Locktite (permatex) brand
Type 4 gasket cement
Follow the links on the web site for type 1, 2 & 3.
Edited by TerrA LX, 27 August 2010 - 07:25 PM.
#31 AbsynthHatch
AbsynthHatch
  • 741 posts
  • Name:Mark
Posted 27 August 2010 - 08:53 PM
With some photo's this could be an awesome sticky
#32 TerrA LX
Posted 02 September 2010 - 08:53 PM
Did you win?
#33 _lostinspace_
_lostinspace_
Posted 09 September 2010 - 07:38 PM
Not yet Terry the new gaskets I got don't look right either and they tell me there the only 2 types at Robbo's so I will try another store and see what they say or find the part number to make sure I have the right ones.
#34 TerrA LX
Posted 10 September 2010 - 11:49 AM
Yeah you have to be careful, there are 4 different heads and alot of makers only do universal gaskets.
Post up a picture of what you ended up with this time.
#35 _lostinspace_
_lostinspace_
Posted 10 September 2010 - 09:18 PM
This is the only other one they besides the one you saw Terry.
Attached File  IMG_2301.JPG   68.46K   0 downloads
When I said I wanted the the U shape cut in the middle hole I was told to cut it out myself, since all the other parts I order were wrong I decided to not worry about it and will go some where else.
#36 TerrA LX
Posted 10 September 2010 - 10:19 PM
That looks like it will do the job if you can not get anything better, it will blow out the gasket if you do not cut it out tho.
If you get stuck with these ones then cut it to suit.
