Front Brakes LX UC
#1 _loz_
Posted 26 November 2005 - 08:13 PM
has anyone out there upgraded front brakes 2 commodore pattern discs and twin piston calipers. If yes, what is involved?? is there any kits available etc...
#2 _CHOPPER_
Posted 26 November 2005 - 08:16 PM
#3 _redlh_
Posted 27 November 2005 - 10:35 AM
Go to Modifications and look at the front brake conversion page.
Posted 08 December 2005 - 01:07 AM
Edited by Jay#2, 08 December 2005 - 01:09 AM.
#5 _CHOPPER_
Posted 11 December 2005 - 12:47 PM
#6 _JNR_ATE_
Posted 11 December 2005 - 02:44 PM
Therefor if you had a set of big feet on the front with close clearance you would need an offset to have the same wheels.
Any truth to this.
JNR_ATE
Posted 11 December 2005 - 05:29 PM
Posted 11 December 2005 - 07:44 PM
#9 _CHOPPER_
Posted 11 December 2005 - 10:15 PM
Posted 11 December 2005 - 11:58 PM
Posted 12 December 2005 - 01:26 AM
The +8mm Torana kit..... this is their standard kit and this is what you WILL be supplied unless you specifically ask for the 0 offset kit
And of course the 0 offset kit.
Due to low wheel availability in anything reasonably sized in Torana pattern, most people use Commodore pattern and wheels. Hence the kit with the +8 offset.
#12 _CHOPPER_
Posted 14 December 2005 - 06:32 PM
Most 8 MM spacers are illegal. Unless you permanently affix it to the hub, then it becomes legal.Ah righto, thanks fellas! I'll just have to take into acount the 8mm of spacer when I order the wheels.
Posted 15 December 2005 - 01:52 AM
#14 _CHOPPER_
Posted 17 December 2005 - 08:57 AM
Posted 22 December 2005 - 10:19 PM
its just that our captain shouldnt really be the captain
Posted 23 December 2005 - 06:54 AM
I never knew that they had the 0 offset option though.
Simmons 15 and 16" rims wont fit. Gotta go 17/18 with simmons unless you space it and have a huge backspacing, like posted above.
Posted 02 January 2006 - 10:00 PM
