Raceme's next upgrade
#51
_raceme_
Posted 26 September 2010 - 08:17 PM
i just want someone to explain how it has those figures. noone has any ideas, all i can think is that on a chassis dyno diff gears must come into play?
#52
_raceme_
Posted 26 September 2010 - 08:27 PM
say there is a 15% loss of torque through the diff, which means it could have produced 1400 at the dyno (no friction).
now divide 1400/3.5 = 400 ft-lbs of torque at the flywheel (no worrying about torque lossed in gearbox).
This was at approximately 5000rpm
so i should have been making about (400*5000)/5252 = 380 hp
this all seems to look right when you factor in diff gears.
Also normally a chassis dyno will graph hp and torque vs km/h because this factors in the diff gears, they only show you rpm so its easier to read (well thats what i always thought).
#53
Posted 26 September 2010 - 08:43 PM
I suspect that the 1200 ft-lbs figure you saw and the figures on the dyno sheet is the raw torque figure measured at the roller which is affected by the gearbox, diff and tyre and dyno roller diameter.
A dyno measures torque and RPM. HP is calculated from the torque and RPM using the formulae.
HP = ( Torque * RPM ) / 5252
Torque = (5252 x HP ) / RPM
How Dynos Work
Dynamometer
Consider an engine that produces 200 ft-lbs at 5000 RPM which is 190.4 HP.
Then we put a 2:1 gearbox on that engine and measure the output at the shaft. We get 400 ft-lbs at 2500 RPM which is (400 ft-lbs * 200 RPM) / 5252 = 190.4 hp.
We know the engine is actually reving at 5000 RPM we can work out the torque the engine is producing (5252 x 190.4 Hp) / 5000 RPM = 200 ft-lbs.
Edited by ls2lxhatch, 26 September 2010 - 08:44 PM.
#54
Posted 26 September 2010 - 08:56 PM
The raw figures given at the start of this massive thread were correct, and even though Anthony mentioned the diff ratio thing and the fact that it was a chassis dyno earlyer in this thread and it was shot down it is actually correct...
Yay happy endings.
Edited by Bomber Watson, 26 September 2010 - 08:56 PM.
#55
_raceme_
Posted 27 September 2010 - 12:32 PM
#56
Posted 27 September 2010 - 12:41 PM
It find it difficult to understand why a dyno operator would choose to plot this torque figure as it is basically useless for gearbox choice or engine comparison. The figure clearly is not engine torque.
To compare engines and select an appropriate strength gearbox you need to know what the engine torque is. The Patrol dyno shows 3000 Nm (2212 ft-lbs) @ 2200 RPM with around 70 kW (94 HP). Surely you don�t think that the Patrol is making 2212 ft-lbs of engine torque. We know that engine torque in ft-lbs = ( 5252 x HP ) / RPM. Therefore the Patrol engine torque without allowing for drive train loss is 5252 x 94 HP / 2200 RPM = 224 ft-lbs.
Based on the Raceme�s dyno results you were looking for a gearbox that could handle 1200 ft-lbs. This indicates you mistakenly believe that Raceme's engine is producing around 1050 ft-lbs to 1200 ft-lbs of engine torque. You also think that that Raceme�s engine is producing more torque than Litre8, the CAPA VE Ute Vortec 409 ci and Rorym�s 355.
I have been looking at G-Force Racing who make spur dog ring, helical dog ring and helical synchronised gears for about 5000 dollars. They look pretty tough but are only rated at 600 ft.lbs of torque which is a bit concerning considering last time i saw on the dyno i was making about 1200 ft.lbs of torque.
As i said it didnt make 1200, it made more like 1050 with an ultra restrictive exhaust and a slipping clutch, one of which has been fixed and the other is getting looked at, hence were just looking at something a bit higher.
Why is it so hard to believe? at 10psi its effectively a 8 litre engine with very high volumetric efficiency, 355 is only 5.7, even assuming R's engine would have been making 100% volumetric efficiency at the top of the torque curve due to the modifications he did to it.
All I have said the whole time is that I don�t think you need a gearbox capable of handling 1200 ft-lbs of torque because I don�t believe the engine is producing 1200 ft-lbs of torque.
#57
_Gunmetal LH_
Posted 27 September 2010 - 03:38 PM
I have no idea what-so-ever if your Haltech can run the trans? May be able to control the lock up converter a 'non elec' TH700R/4L60? Again- no idea...
But I know the lockup function SHOULD be used- something to do with preventing overheating when in overdrive.
With my VN (V6 but same kind of operation with a V8) when the converter 'locks up' the revs drop by 200-400 rpm depending on the road, wind, blah blah blah.
Edited by Gunmetal LH, 27 September 2010 - 03:41 PM.
#58
_raceme_
Posted 27 September 2010 - 03:51 PM
i totally agree, sorry, im sure this would have been sorted out in about 5 minutes face to face, so hard to explain things on the net. i was never doubting that i didnt make 1200 ft-lbs, i just wanted someone to explain why the dyno machine was giving such a skewed readout.
and coming back to gearbox choice, according to your figures, something that handles between 400 and 600 ft-lbs would be perfect?
#59
Posted 27 September 2010 - 05:07 PM
For peace of mind, give COME racing a call and ask them what sort of torque you can expect from your combination and any future plans you have for the engine.
#60
Posted 27 September 2010 - 05:55 PM
_raceme_
Posted 27 September 2010 - 10:05 PM
#62
Posted 27 September 2010 - 10:12 PM
WHY THE frOck IS AN ELECTRICAL ENGINEER AFRAID OF A LOCK UP TORQUE CONVERTER???
_raceme_
Posted 27 September 2010 - 10:33 PM
#64
Posted 28 September 2010 - 07:03 AM
Sorry to wade in late on the discussion, but doesn't that only apply when a lockup converter is installed? I.e. if you don't want the lockup, you buy a standard design converter and all is well?But I know the lockup function SHOULD be used- something to do with preventing overheating when in overdrive.
#65
_Gunmetal LH_
Posted 28 September 2010 - 02:50 PM
T350's never had them? So I guess you'd be fine?
#67
Posted 28 September 2010 - 08:35 PM
Yes, electric controlled - easy done on any injected engine as all the ECUs have provision for it. Its basically only a switch, I've also heard of people simply using a manual toggle when running behind a carbed engine but that seems a bit roughI thought the lock up was electric for some reason, most likely wrong though.
edit: it has just occurred to me that the lockup converter issue is probably the same as street driving with a high stall converter - driving too far at speeds where the converter is not fully engaged causes them to overheat, and this may occur with tall gearing (such as the standard Commodore 3.08:1 diff) and the overdrive ratio? The converter clutch would solve this problem, but assuming that you have done your normal homework with regard to stall rpm and cruising speed I guess you wouldn't need it
Edited by 76lxhatch, 28 September 2010 - 08:39 PM.
#68
Posted 28 September 2010 - 08:43 PM
From what i gather the lock up stally helps with this, so i would think its a good thing???
And its electric like i thought, so back to my question, why is my resident electrical engineer afraid of a lock up torque converter???
_raceme_
Posted 28 September 2010 - 09:54 PM
if this is controlled by the ecm then its all sweet, because the haltech should have provision for this. i know the ls1 ecm controls the auto, but i am wondering if the older 304 computers controlled the auto through the bcm (body control module).
#70
Posted 28 September 2010 - 10:14 PM
I can paint real purdy
From the painters mind, would it not matter a shit what model car the motors out of so long as your Haltec can support it?
Also i'll wager a guess that the BCM is still sitting in the car in your dads back yard.....Not that i have a frOcking clue what a BCM is apart form Body Control Module....What it does is beyond me. Why the frOck do you need to control the body? its all welded together and shit, no control needed.
Furthermore, you built that flash circuit board thing to run your thermo fans, surely this wouldent be out of your realms of wonderfullness.
Edited by Bomber Watson, 28 September 2010 - 10:15 PM.
#71
_Gunmetal LH_
Posted 28 September 2010 - 11:14 PM
I think it runs off throttle position and or vacuum (don't know how that would work with a boosted engine?) and speed?
#72
Posted 29 September 2010 - 06:14 AM
Nope its not that complex, all done by the ECM/PCM. The good thing about doing it properly is that you get a lot more fine control (which you can really just set and forget) - minimum speed, unlock delay, etc etc which all help to make it work well while being reasonably unnoticeable to the driver.i am wondering if the older 304 computers controlled the auto through the bcm (body control module).
The BCM introduced in VRs controls the security system along with a number of the controls and systems not related to the engine. If you have a PCM designed to work with a BCM all you need to do is disable the security in the tune and you have everything you need to run the engine and trans.
#73
_raceme_
Posted 29 September 2010 - 09:01 PM
#74
_evil UC hatch_
Posted 01 October 2010 - 03:08 PM
"FULL MANUAL 4l60E FOR HOLDEN V8 AND I THINK IT WILL GO BEHIND AN LS ENGINE AS WELL
I am selling for a mate a 4l60E as he is changing to a glide built by RVO atuomatics in dandy it is full manual shift no computer needed to run it as it has a custom electronic shift kit, has a TCE 8" converter with positive stator angle. The converter has 6000 rpm stall but drives great on light throttle better than my old 4500, converter alone cost $1400 costs $400 to get it stall resized. The box has not done much work as car is rarely driven and is in excellent condition. He is looking for $2200 ono which is nothing compared to what it cost to build, open to offers has the reciepts with all work done on it built to handle 600hp, will come with tailshaft and cross member if wanted. Box is still in car but will be coming out in the next week or 2 so any serious buyers can see how it drives very snappy and responsive Call Pete on 0428339851 or P.M me
Open to resonable offers"
#75
Posted 01 October 2010 - 03:35 PM
You have stated that the car is a difficult to drive with the current setup. Why not invest some effort and money into a suitable clutch? There are clutches availabe that are light on the pedal, yet can handle plenty of torque. There are guys running blown VE's getting around with manuals and they are no problem to drive every day. I dont see why you could not have a clutch made to suit your requirements. It will not be cheap, but will still cost less than converting to an auto.
If you are set on converting to an auto, then a properly set up (correct combination convertor and lock up setup) 4L80E will be nice and smooth to drive. But will sap more power than a manual and most likley will be heavier. I would not reccomend a full auto arrangement though. A nice firm shift kit (with a decent convertor) will be just as quick, but still offer some comfort.
P.S Roller dynos measure Tractive Effort at the wheels (in NM or ft/lbs) not engine torque. To convert this tractive effort to engine torque you need to consider the tyre size, diff ratio and gearbox ratio used..... Tractive effort is a value much higher than that of engine torque (using the same units)
