Help ASAP
Posted 01 May 2006 - 06:25 AM
About half way to work this morning (at 5:15am !!) I pulled up at some lights when all of a sudden the starter motor kicks in, I killed the ignition but the bugger was still going! I pulled over into a car park (lucky there was one handy) and I had to pull the earth lead off the battery.
What would have caused this to happen?
I take it there's a problem with my ignition curcuit?
Please help as I need my car 6 days a week!
Any help appreciated......
Posted 01 May 2006 - 10:48 AM
#3 _TORANR AMORE_
Posted 01 May 2006 - 10:59 AM
Also check the back of the Starter motor.
Posted 01 May 2006 - 11:44 AM
Disconnect the Starter motor and then test the ignition.
By testing the ignition, what do you mean? How am I testing it and for what (Sorry for the ignorance, I don't have much knowledge of anything elec!)
Check the back of starter for what?
Posted 01 May 2006 - 01:21 PM
Posted 01 May 2006 - 01:26 PM
Check the ignition rod isn't just bent for starters, but otherwise, may need to replace the whole switch itself if it's shorting out...
This is in the barrel?
#7 _dave720gtr_
Posted 01 May 2006 - 01:33 PM
#8 _The Baron_
Posted 01 May 2006 - 01:47 PM
This is all happening at the starter motor.
Extractors have a habit of frying starter motor cables, especially on 6's.
Life is easier when checking this on a 6.
Posted 01 May 2006 - 01:54 PM
Posted 01 May 2006 - 02:50 PM
Posted 01 May 2006 - 07:05 PM
started the car,starter still engaged.turned ignition off,starter kept going.
Turned out that the screw holding the cap of the solenoid had fallen out and wedged between the terminals causing it to go banana's.
just something else to look for.
does sound like your ignition switch has moved though
Damo
Edited by LXdamo, 01 May 2006 - 07:06 PM.
#12 _TORANR AMORE_
Posted 01 May 2006 - 07:36 PM
sorry, I mean disconnect the ignition feed wire like LXCHEV said and then, with the ignition barrel turned to its off state, test to see if the wire is live with current as it would be in order to turn the starter motor on. If it is then I'd be looking at the switching mechanism within the steering collumn like the other guys said, it may be somehow shorted or jammed or something.Disconnect the Starter motor and then test the ignition.
But all this is assuming that there is nothing that is shorting the terminals at the rear of the starter motor. remember if you short two of the terminals (and they are very close), it will turn on and stay on, like LXdamo said.
Posted 02 May 2006 - 06:00 AM
I've removed the starter motor, an auto elec's gunna have a look over it. I did notice the 'purple' wire was missing some insulation..... what's the best remedy here? Good old insulation tape? Or heat shrink hose?
I really hope it's not the switch.... sounds very fiddly!
Thanks again!
#14 _The Baron_
Posted 02 May 2006 - 10:23 AM
Ask an auto electrician what you can use.
I used a little bit of fibreglass insulation tape on my old 6 hatch, rough but worked.
Let us know what you find as I'm sure we will all have this problem at some time.
#15 _hrt1and2_
Posted 02 May 2006 - 03:57 PM
#16 _Loki_
Posted 02 May 2006 - 06:46 PM
I ran my starter wires (insulator taped) inside a heater hose, which was tied back and ran as far away from the extractors as physically possible right up to the starter.a bit of tape, and cable tie it back away from the extractors. Should do the job.
Has worked like a charm so far, those wires still look like new at the moment.
Posted 02 May 2006 - 11:33 PM
(For anyone who doesnt know.. Firesleeve is a fibreglass tubing with plastic outer that is designed to go over fuel lines to minimise heat and abrasion and also resist direct flame in the event of a fire.)
Cheers. Best of luck Knoath!!
